Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 03-09-2008, 03:26 AM
looking9 is on a distinguished road
Need Help to find micro milling service shop
I am working with microfluidic system for my scientific research and I need a metal master mold. The pattern of the master is like a stamp which has a couple of tiny bars on top a base. The width of the bar is 0.1mm and height is 0.5mm. I am thinking to buy a desktop CNC milling system but I am debating because CNC is not my major. Another option for me is to find a shop to do this. Anyone can help me to find a shop which has micro milling capability and also is willing to do small volume samples? I have different patterns to mill but for each pattern I just need very few samples. I am located in Chicago area. I am will to accept any reasonable price.
Thanks a lot.
Old 03-09-2008, 09:27 AM
zcases's Avatar
zcases is on a distinguished road
what is the spacing between the bars? Can you post a sketch with tolerances and material requirements?
Scott
http://www.scpconcepts.com
Old 03-09-2008, 11:13 AM
The material could be any metal which could be easily milled, like: stainless steel, aluminum, copper or brass. The tolerance is like ±10% of the dimension in my drawings. I also attached my drawing.
Thanks a lot.
Old 03-09-2008, 05:43 PM
pixburghenat is on a distinguished road
Thanks a lot.
Stick with the brass.
Is there a research machine shop at your university?
Or one at a nearby University that you could use?
I'm only asking because this is the type of work I've done with a medical school research machine shop and now with the engineering school machine shop. Sorry, I can't quote on outside work and we don't have a high speed spindle anyway.
...again, stick with the brass.
Scott
I can create a Solidworks model for you, no cost. version 2007.
Some of my best finds were in the trash....
Old 03-09-2008, 06:26 PM
I have a Solidworks model. I need to add the corner radius.
here's a jpg.
Scott
Name:	brass master stamp.jpg‎
Old 03-09-2008, 06:54 PM
Thumbs up
Thanks, Scott
I really appreciate your help on making me a Solidworks model. I will take your advice and stick with brass. And if you don’t mind, would you please tell me why brass is my first choice?
A high speed spindle won't be a problem for me or at least I don’t think it is the crucial for my sample because in my mind, a high speed spindle can just make the mold better and a normal spindle can make it. I don’t expect to use the same machines listed in the literature. I just want the mold to be made.
Pang
Old 03-09-2008, 07:26 PM
mactec54 is on a distinguished road
Hi looking9
what are the corner Radiuses needed & it depends what you want to do with it
as to what material is needed
Mactec54
Old 03-09-2008, 08:44 PM
zcases's Avatar
你是中国人吗? 我看了你的名字。 我只好奇了。。。。。
Old 03-09-2008, 09:42 PM
Here's the models.
Scott
I have Edrawings of both also, posted below.
You'll need the viewer from solidworks.com
...and zcases said:
You are Chinese? I read your name. I just curious about the.......
Old 03-09-2008, 09:53 PM
edrawings and models.
You'll need edrawings (free) from solidworks
Scott
  #11   Ban this user!
Old 03-09-2008, 09:57 PM
Pang,
If you are flexible with the sizes of the inside radius, it will be less costly to make. Say a inside radius of .25mm or .30mm would be a bit easier or even bigger.
Scott
  #12   Ban this user!
Old 03-09-2008, 10:58 PM
Yes, I'm Chinese.Good eyes. 是的,我是中国人。你的眼力不错。
Cnc Milling Shop delhierro Machinist Feedback 3 06-21-2008 06:09 PM
where to find compacitor for shop fox m1007 hmcl281 General Metal Working Machines 3 12-08-2007 09:26 PM
Help To Find Online Tool Shop Brenck General Metalwork Discussion 1 01-27-2007 11:12 AM
White Paper: Highspeed milling with micro-tools HighSpeed Product Announcements & Manufacturer News 0 03-03-2004 09:29 AM
micro-edm roysol CNC Plasma and Waterjet Machines 1 10-15-2003 02:01 PM
