| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
I am looking to have some bar ends turned for my motorcycle. The overall size will be about 1 1/2" dia x 1 1/2" long (give or take, final measurements will be figured out if I can move forward with this). This doesn't need to be high strength aluminum or anything of the sort. Just something that'll look good and not be to susceptible to corrosion (unless you can anodize as well). It would be easiest for me if you could source the aluminum as I have absolutely no clue where to start looking. ![]() Attached is a jpg of what I'm wanting. Thanks in advance for taking the time. Beardking |
| Actually I'm needing some very similar parts as well, so could any respondents CC me with quotes? Mine would be almost identical, but with a longer, larger radius, and turned on tube (1.5" OD, 3mm wall thickness) instead of solid. Exact dimensions to be sorted out later, just after a rough idea on cost. Essentially this one without any drilling / boring. I'd also be needing lots of, say, 20 a month. |
| Thanks to all of those that were so kind as to send me quotes for the bar ends. I have arranged to have these made by a member here and I'm looking forward to receiving them in the near future. If I can contain my excitement once I receive them, I'll try to remember to post pictures for all to oggle. ;-) |
| RFQ for motorcycle parts | CycleOpsUSA | Employment Opportunity | 1 | 02-18-2008 08:04 PM |
| Motorcycle Mirror Mounts | MFP-2241 | Employment Opportunity | 14 | 10-14-2007 07:20 PM |
| where to source motorcycle blank hubs? | SRT Mike | General Metalwork Discussion | 3 | 09-17-2006 04:12 AM |
| Can you use a lathe to machine a motorcycle wheel? | t120rmike | General Metalwork Discussion | 13 | 05-29-2006 12:38 PM |
| Motorcycle rims | RayDOsity | General Metal Working Machines | 36 | 04-21-2004 03:57 PM |
