Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 02-18-2008, 11:05 PM
98vert is on a distinguished road
RFQ for steel parts
Looking to find a supplier for the attached parts. I'll need to get 30 prototypes of each for validation testing prior to production orders. Production quantities will be 1000/part. 5-6 orders per year. Please let me know price and delivery for both the 30 prototypes and the 1000 part orders. If you're not interested, or don't have the capability to do the heat treating and grinding, but would still like to provide machined parts, let me know. Please let me know if you have any questions. Thank you.
Rob
Product Innovations LLC
product_innovations@yahoo.com
860-517-9461
ID:	53752   Click image for larger version
ID:	53753   Click image for larger version
ID:	53754   Click image for larger version
Old 02-18-2008, 11:10 PM
DSL PWR is on a distinguished road
What parts?
On all equipment there are 2 levers...
Lever "A", and Lever F'in "B"
Old 02-18-2008, 11:17 PM
Sorry, attachments won't work for some reason. I'll try again in the AM.
Old 02-25-2008, 08:34 PM
san san is offline
san is on a distinguished road
Reply quote
Please check your email. I sent you an email from santosh.khatri@gmail.com
Old 02-26-2008, 10:18 AM
Some people have said that the drawings were fuzzy. Please make sure that when you click on the attachments, open them up to the regular size. After you click on the drawing and it comes up in the viewer, click on it again, put your cursor on the print and a box with arrows in the lower right hand corner of your screen will pop up, hit it if the drawing is not expanded. That should make it enlarged to the proper size so it could be viewed clearly. If you still have a problem, PM me and I'll send you the individual files.
Also, for some reason I screwed up my phone number by accident (brainfart). The right one is below.
Thanks.
Rob
860-517-9648
Old 02-29-2008, 03:12 PM
Going on 10 days without a quote yet. I've had a lot of interest but no quotes. Anyone seriously interested? Anyone interested in making blanks for me? I'll get them heat treated and ground. Let me know. Thanks.
Rob
860-517-9648
Old 03-02-2008, 10:19 AM
heavy metalmach is on a distinguished road
i wish i had the equipment to do that kind of work for you because it looks like it would be a good job to have one the books.
Old 03-03-2008, 07:33 AM
MFG. SOLUTIONS is on a distinguished road
RFQ
Dear Rob,
I left you a message. I have a couple questions regarding the parts. We can definitely make them. Three of the prints are calling for heat treat, is this an oversight or does the collar also need heat treated? Is the .0004r in the corner of the groove absolutely necessary on the pivot shaft or is functionality the main concern (tool wear could take up all this tolerance)? The radius on the socket fin is that truly offset from the centerline, having a hard time making out this print. Please call or respond so I can give you an accurate quote.
Sincerely,
Micah J. Hilditch
Sales Engineer
MANUFACTURING SOLUTIONS
p:440.354.8113
f:800.878.5648
mhilditch@hventure.net
Old 03-03-2008, 08:43 AM
Micah,
Thanks for catching the groove radii mistake. The number should be .1mm Max, instead of .01mm Max. The collar print is correct, it does not need a HT. The other 3 components do need HT.
Rob
860-517-9648
Old 03-04-2008, 03:02 PM
Quote sent
Dear Rob:
I e-mailed you a quote this afternoon.
Micah J. Hilditch
V.P. of Marketing
440.354.8113 P
800.878.5648 F
Laser Cut / WaterJet Mild Steel Parts GNS Employment Opportunity 0 10-02-2007 05:00 PM
RFQ for 3 parts - 8620 steel 98vert Employment Opportunity 7 02-01-2007 08:04 AM
RFQ: 35 parts 4340 steel Eddieweeks Employment Opportunity 1 08-21-2006 11:17 AM
Annealing steel parts after welding? Edster Welding, Brazing, Soldering, Sealing 9 03-31-2006 03:38 PM
RFQ: Stainless Steel Parts MadFlava Employment Opportunity 5 07-30-2005 01:43 AM
