| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
I'm working on an engine and wanted to know if someone would put up some R&D time to get it up and running, I just need the rotor cam done and it will be open source to who ever wants to build these and sell them. look at the Icon at the pink foam cam. we have a private site to members only that build energy efficent devices and is not open to the public you may be invite to help on this project. NAD agreement is involved . Mike bush |
| the diamiter is 6 inches and the lobes are 120 degrees as to the black marks in the photo. the edges is 3/4 inch , the bearing surface on the face of the rotor , this is where the piston rod rides at 90 degrees to the rotor the bolt is where the drive shaft goes. I used a 86c frame electric motor shaft and bearings. the critical part is when thr rotor turns the sine and cosine change to keep the bearing tight and not pinching the rotor. you can take a parir of calipers and move them 90 degrees on a pice of paper and seee the angles change. It will be in a 12 cylinder engine and has only one stroke due to the turbo blowers on it. It runs on vaporised fuels and hydrogen from a cell i'm testing. here are some other parts and assemblies such as the piston rod guide and set up to the cylinders. if you need other info feel free to ask. I fel the engine will produce 50Hp or better and a larger model will produce 200hP and it is all tork no lag 6 cylinders fire at one time then the other 6. I feel i have come up with a satisfactory oil pump system that is a screw type that is in the sump. the 4 cells is a test cell for the Hyd. |
| Hi Motorcoach1 With what I see your design is not new there are many Patents on this type of Engine It is used a lot for hydraulic Pumps as well as transmissions ( Honda has one ) you can find lots of information under Swash Plate Engine which is the same concept as your engine I hope this helps to move foward in your design
__________________ Mactec54 |
| I googled swash plate and got 11 hits all from CNCzone, not much help. I know what you mean by swash plate, they have movement like on the collective on a helacopter. this is a set rotor on the shaft. I have looked at many patents, but that doesn't get the part made. thank you for your input. Mike |
| Thank you Mactec54 , most folks i have talked to told me about the difaculty on this part , but I keep chugging along been at the design for 2o years now and still would like to build one. I'm not going to patent it just open source it to who ever wants to make one. it should proform quite well and the guys that ***** about the gas deal- well what ever- this is green and gives good power for the money. i run my bus on Efuel and HY I make myself so the gas prices don't realy bother me when I by 10 gallons a month. I machine glass products and the pays not like Fla but I'm happy and the boss pays the electric bill ,lol. I live 65 miles from home so I stay at the plant during the week. @ bob if you want to make one go ahead , look at it as a big model engine, Other than the cam it's stright forward build. no fancy machine work after that. I'll post more If you like but will have to be another thread. |
#10
| ..so, you're looking for a freebie? ...can I also assume you would like solid models and detail drawings too? with revisions? Just off the top of my head, one could have $1500 in this job. ...and that person would get 'open source rights'? Since posting this in a public forum, you have given away any intellectual property rights to the design. Now if there's more to the story, I'm sure once the prototype is done there will be modifications done to make it workable. ...am I close? I'm not critizing you or the project, but the approach is not what anyone with any sense wants to be a part of. After 35+ years machining and prototyping, you know when someone is trying to take you for a moron. my .02 enat
__________________ Some of my best finds were in the trash.... Last edited by pixburghenat; 02-20-2008 at 10:31 AM. Reason: grraammeerr |
#12
| You may want to contact a local college or Tech School with your idea, they may be interested. I advised teams of engineering students who worked on solutions for companies in our area. The class was product realization utilizing rapid prototyping and rapid manufacturing, it is a great success. The students get real experience developing an idea or working a solution to a real need. In Tech schools, there's a program called VICA, who could help develop the idea. You could help by donating only your time, there could be no cost to you and a great weath to students in need of your experience. my other .02 :-)
__________________ Some of my best finds were in the trash.... |
| someone to build my prototype | samvoneill | Want To Buy...Need help! | 3 | 01-19-2008 03:35 PM |
| Quote Please Prototype | Bluesman | Employment Opportunity | 2 | 07-04-2007 12:09 PM |
| pcb prototype | xlukkajr | General Electronics Discussion | 2 | 02-21-2007 03:14 AM |
| [cad] Cnc Prototype Idea... | Brunow | Mechanical Calculations/Engineering Design | 5 | 01-31-2007 07:00 AM |
| Prototype. | impact | Employment Opportunity | 4 | 04-29-2005 02:10 PM |
