Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 02-07-2008, 02:50 PM
raidfibre is on a distinguished road
Exclamation RFQ: thin brass bracket - water/laser/?
1) Material type: brass 1/16" sheet
2) You supply material
3) Please quote 20, 100, 200.
5) Required time frame:
I need at least 2 pieces shipped 1 week after purchase order. After that depends on total quantity.
6) RFQ ending time
1 week
9) Make known any special treatments/finishes not necessarily related to the machining process.
Tolerance +.030/-.000
Process doesn't matter as long as it works and the price is right. If something about my drawing doesn't work with your process (or makes it more expensive) please let me know and I will see if I can modify it.
Thanks a lot!
Martin K
Old 02-07-2008, 10:20 PM
MegaMoog is on a distinguished road
PM Sent
Old 02-16-2008, 09:36 AM
Cebby's Avatar
Cebby is on a distinguished road
Was this awarded? I also sent a PM earlier.
www.TOOLandFAB.com
www.ControlledCutting.com
Old 02-19-2008, 07:38 AM
Yes - awarded to you.
questions re water system for CO2 laser goddessofchaos Laser Engraving & Cutting Machines 13 02-13-2012 01:42 PM
What is the best way to cut thin wall brass tubing? lerman General Metalwork Discussion 9 03-27-2009 02:58 PM
RFQ: Need Cnc Water Jet, Laser Or Plasma Cutting Services kenrik Employment Opportunity 0 09-07-2007 11:47 AM
RFQ - water/laser jet 316SS zcases Employment Opportunity 2 01-09-2006 04:39 AM
Advice on laser cutting of thin stainless sought ElectronicsEng Employment Opportunity 2 10-06-2005 01:04 AM
