| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
This is an exhaust manifold flange drawing for a M20B25 BMW L6 motor for my '90 325i. The bore spacing is 91mm (I'm pretty sure). The drawing is mixed mm and in right now, but it is not a final drawing. I don't have exact specifications yet, just a rough layout. I don't even know what type of steel it should be made out of. My plan is to have someone cut this, then purchase a universal header kit and cut and weld until it's a complete long tube header. Thanks! Jeremy Last edited by mmmjboner; 01-27-2008 at 09:56 PM. |
| Hi: You could purchase the X gasket and reverse engineer, to verify the dimensions, or plot 1:1 and fit on the head. As far as manufacturing goes, I'd recommend matching the header material to the flange in order to be able to get a good weld. This part is a prime candidate for waterjet cutting, or plasma cutting the profile,bores, and then drilling the holes with a 1:1 template glued to the part. regards |
| Thanks! Jeremy |
| Help milling exhaust flange | pauls | General Metal Working Machines | 5 | 12-31-2007 06:42 AM |
| 4' x 8' table, how much CFM do I need for exhaust fan? | blackhollowmfg | CNC Plasma and Waterjet Machines | 8 | 05-16-2007 03:50 AM |
| RFQ Intake manifold Flange Aluminum | SouthForkSam | Employment Opportunity | 10 | 05-02-2007 07:08 PM |
| How Can I Deburr A Manifold? | lerman | General Metalwork Discussion | 4 | 08-02-2005 09:35 AM |
| machining a manifold | MBG | General Metalwork Discussion | 4 | 04-08-2005 12:41 PM |
