Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 01-23-2008, 09:52 AM
fredhh47 is on a distinguished road
Turning and broaching needed
I have three different parts that I need in a fairly small quantity, probably about 100 of each or less. I will describe them briefly, and if you might be interested, please contact me for prints and specifics.
The first part is a steel bushing, 12L14 or similar, the alloy is not critical. It is to be made from at least 7/8" dia. stock. The overall length is about 1". It has a 3/8 reamed or bored hole thru, a taper on one end, and a 9/16-18 Left Hand Thread on the other. It has a couple other features including an undercut. (It resembles a mushroom) If you have the faciltiy to black oxide or "tool black" the part, it would be a plus.
The second part is a ground 1/4" diameter shaft with a 1/4"-28 right hand thread for about 3/4" at one end, and a 3/8 diameter portion at the opposite end which must be drilled and broached to .203 square for a depth of perhaps 3/8 to 1/2" depth. The shaft is to be made from a heat treatable steel that can be hardened and tempered, post-machining. It must be quite straight when finished and the 1/4" diameter must be very accurate.
The third part is essentially the same as the end portion of the above shaft. It should be made from stress proof or similar steel, about 7/8" long, 3/8" O.D., with a taper at the broached end. It must be drilled and reamed to .251 diameter 5/16" deep, and thru drilled about .220 diameter and broached to .203 square. The broaching can go all the way thru. Black oxide or tool black optional. Another similar part is under development.
Minimum order quantity would be 50, but I might want 100, depending on price.
Interested parties please post replies here or contact me at mercat@clarityconnect.com
Thank you.
mazak integrex broaching precisiontork Mazak, Mitsubishi, Mazatrol 5 10-27-2008 07:57 AM
Live Tooling Y-Axis help needed Hitachi Seiki Turning Centre Dover G-Code Programing 8 07-06-2007 10:49 PM
Broaching advice Al_The_Man General Metalwork Discussion 9 12-19-2006 05:03 AM
Automating the Broaching process Donald Mechanical Calculations/Engineering Design 20 10-20-2006 04:09 PM
Broaching without a broach or press? Chris D General Metalwork Discussion 9 09-23-2005 02:47 AM
