| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
Thanks for all your quotations. I appreciate it. I have awarded the job as of 12/18/07 9pm. Thank You again. Mark. Im interested in getting a quote to have 50 spacer plates machined out of 6061-T6 Alum. I can send the model in a Mastercam or Solidworks 2007 format if needed. I would like to have these before January 30 if possible. The only critical tolerance is the center thru hole diameter, plate thickness and parallelism. (+ or -.002). A machined surface finish is fine, no need to sand or polish surfaces after machining. All edges should be chamfered 45 deg. .020-.050. The four 7/16 holes are just clearance for 10mm flange bolts. A drilled hole will be ok. All dimensions are english. Thank You. Please let me know if you have any questions or if there is anything I missed. Mark. m5christopher@yahoo.com or just reply to this thread. Last edited by cncharleydude; 12-19-2007 at 01:52 AM. Reason: I accepted an offer/quotation. |
| Sorry about that, I will make sure to give the quoting process more time in the future. I do have additional jobs in the works, and I will post them on cnczone once I finalize the design. Probably sometime early next year. Mark. |
| RFQ - Need spacer made | Runner4404spd | Employment Opportunity | 14 | 12-13-2007 10:00 PM |
| A Few Alum Plates Needed | elogicca | Employment Opportunity | 10 | 05-30-2007 04:57 PM |
| RFQ: 1/4" Black G10 Intake Manifold Spacer | Aaron92SE | Employment Opportunity | 4 | 01-29-2007 11:09 PM |
| WTB 12" Super Spacer | Fudd | General Metal Working Machines | 0 | 07-14-2006 02:43 PM |
| Super Spacer | Zumba | General Metal Working Machines | 5 | 03-21-2006 06:08 PM |
