Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 12-12-2007, 06:26 PM
valco is on a distinguished road
Exclamation Employment opportunity Citizen Programer/Setup/Operator Cincinnati, OHIO
Ohio manufacturer located in northern Cincinnati area has an employment opportunity for an individual experienced in the programming and operation of CNC Swiss turn equipment. This is a new position in a growing machining operation that is part of a leading international manufacturer. The duties will require the start up of a new manufacturing cell including programming, operation and maintenance of Citizen turning equipment.
We have a Citizen L-20, and L-32. We also Have a Tsugami Swiss turn also. We also have a host of VMC, HMC, B-axis Lathe, Multi spindle conventional lathes.
We are hiring for 1st shift 7:00-3:30 No travel or weekends required. We operate a Climate controlled shop.
We are an ISO9001 cerified Global Corp. that produces Glue application equipment.
Please send resumes to eric.frey@valcocincinnatiinc.com if you are interested.
Employment opportunities - CNC operator, CNC setup cadman Employment Opportunity 1 08-30-2010 02:41 AM
Wayne, Michigan: Wanted CNC Programer and Operator rwhit1962 Employment Opportunity 3 11-26-2007 07:48 PM
Employment Opportunity Haas_Apps Employment Opportunity 1 12-26-2006 09:17 AM
Employment Opportunity maggirl Employment Opportunity 2 10-01-2006 11:42 AM
Employment Opportunity NWCNCHR Employment Opportunity 0 04-15-2005 11:57 AM
