Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 12-01-2007, 08:02 PM
Kingjamez is on a distinguished road
RFQ- Aluminum Disks.
I need a quote on qty:5 ea. and qty: 10 ea. of the following aluminum disks.
Diameter: Thickness:
4" 1/2"
4.5: 1/2"
5" 5/8"
5.5" 5/8"
6" 5/8"
6.5" 5/8"
7" 3/4"
7.5" 3/4"
8" 1"
8.5" 1"
9" 1"
I'd like each disk to have a hole marking the center that is 1/4" or smaller.
Tolerance on each disk diameter is +/- 0.125"
Tolerance on each disk thickness is +/- 0.125" but should be uniform in thickness.
Tolerance on wedge is +/- 0.05"
Using cheap aluminum is fine, the tooling plate from http://www.sandsmachine.com/alumweb.htm would be fine.
Thanks!
-Jim
Old 12-01-2007, 09:33 PM
ddprecision is on a distinguished road
I will have a quote for you on monday, sometime in the afternoon.
Old 12-02-2007, 01:05 AM
cn00728 is on a distinguished road
PM sent
Old 12-03-2007, 10:56 AM
Lillitaly is on a distinguished road
Will have a quote to you by Wednesday
RFQ Sent
Old 12-13-2007, 06:22 AM
Thanks for all of the quotes. I was unable to garner enough orders in the telescope making community to proceed with this order.
-Jim
RFQ: 12/13 guage stainless disks, 2" diameter InspirationTool Employment Opportunity 4 10-08-2006 09:18 AM
390 Aluminum JPMach General Material Machining Solutions 3 09-13-2006 09:18 PM
Divided plastic disks anchornm General Metalwork Discussion 0 05-21-2006 09:41 PM
A2100 Hard Disks tricky General CNC (Mill and Lathe) Control Software (NC) 3 05-28-2005 09:48 AM
A2100 Cincinati Hard Disks tricky General Metal Working Machines 0 05-28-2005 08:03 AM
