Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 10-26-2007, 12:53 PM
SPEEDRE is on a distinguished road
Four plates milled Alum.
Hello, I need to have a quote on aluminum plates milled and drilled. There are two of each size, left and right hands, see attached for specs. I will supply the stock and return shipping. Also include turnaround time. Thank you
This job is closed. Thank you all.
Old 10-26-2007, 01:28 PM
cdlenterprises is on a distinguished road
On the base end plate there are 4 holes along the bottom. What dia. are they?
I don't know much about anything but I know a little about everything....
Old 10-26-2007, 04:12 PM
ddprecision is on a distinguished road
Hello Couple of questions for you, Stage Upgrade. Can you have a radius where the 22 deg angle meets the 2.00 wide dim. How thick is this material? It looks like there are holes coming thru the part from the side if so what dia. and how many? Base end plate You have 4 holes at the bottom of the part, What dia. are they? You want two of each part correct? Everything is +/-.005?
Old 10-29-2007, 02:21 PM
Bump???????
Old 10-29-2007, 04:29 PM
prototypeCNC is on a distinguished road
I believe he already has it filled.
Old 10-29-2007, 05:39 PM
Thanks, I missed his edit.
Anyone need something turned/milled (manual) skmetal7 Employment Opportunity 2 08-03-2007 11:11 AM
A Few Alum Plates Needed elogicca Employment Opportunity 10 05-30-2007 04:57 PM
Looking for Milled Compressor Wheels AMCTony Jet Engines and Ram Jets 1 05-16-2007 07:17 AM
RFQ Al plate/milled roninB4 Employment Opportunity 8 09-07-2006 01:23 PM
Never milled but have a project mikesativa General Metalwork Discussion 9 03-22-2006 01:24 PM
