Results 1 to 11 of 11
Thread: CNC Milled / drilled logo on wood
    Apr 2005
    I need a "W" drilled out on wood pieces. The wood is about 3/8" thick. Here is the specs and picture
    15 piece run
    Wood is roughly 9 x 9 and the "W" needs to be centered on the wood and the "W" need to be 4 x 4 inches.
    Drilled holes 1/32" in diameter. Apply tape on the bottom side to prevent splinters. I will supply the wood and you mail back the wood when completed....
    See picture of how the "W" is suppose to look like...
    I would like to see a picture of prototype on scrape wood before running production.
    James Green
    Attached Thumbnails Attached Thumbnails CNC Milled / drilled logo on wood-w.jpg
    Registered zcases's Avatar
    Apr 2005
    What kind of wood, and how thick is the wood?
    http://www.scpconcepts.com
    Apr 2005
    Wood
    Wood is cheap soft stuff and about 3/8" thick. I can change the drill diameter to 1/16" if that helps....
    James
    Aug 2007
    How many holes per inch do you want
    Apr 2005
    Holes per inch
    This is only a company logo so there is no specs on holes per inch. Just make it look good. That's why I ask for a picture of a prototype run before running the production pieces.....
    James
    Feb 2006
    James,
    I just sent you a PM price.
    Doug Pryor
    David Wolfe Design, Inc.
    Akron, OH
    www.davidwolfedesign.com
    depryor@davidwolfedesign.com
    Oct 2003
    N. Illinois USA
    Thumbs up quote
    How bout a Buck-a-piece!
    You pay shipping, both ways
    Feb 2007
    Can I Use My 22-250 At 200 Yards?
    You Pay For The Bullets
    Bad Dog
    Registered Khalid's Avatar
    Apr 2006
    Pakistan
    free of cost just u pay shipping cost
    Aug 2007
    Qoute
    Quote Originally Posted by green127045 View Post
    15 piece run
    James Green
    James,
    I Could do this with my Rotary Engraver, my concern would be that 1/32 holes would not show up that well
    I could also do this with my laser engraver not have to go all the way thru the wood and I would just burn dots instead of drilling holes
    either way $3:00 a Piece and you pay shipping both ways
    Dustin
    Apr 2005
    CNC Milled / drilled logo on wood - DONE
    Thanks for the quotes and the job has been awarded.
    Thanks again
    James Green
    1. projecting drilled holes
      By dpark1 in forum Mastercam
      Last Post: 08-24-2007, 11:17 PM
    2. Drilled Acrylic
      By kdoney in forum Employment Opportunity
      Last Post: 06-12-2006, 07:28 PM
    3. RFQ: UHMW Cut to length and drilled
      By mrbaseball in forum Employment Opportunity
      Last Post: 11-09-2005, 06:34 PM
    4. Drilled Holes
      By jonbanquer in forum NCPlot G-Code editor / backplotter
      Last Post: 05-25-2005, 12:17 AM
    5. Are sherlines drilled and tapped??
      By BriteHarry in forum Mini Lathe
      Last Post: 10-14-2004, 08:36 PM
