Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 10-20-2007, 07:48 PM
browniecrystal is on a distinguished road
Seeking steel plate mfr.
I have a very limited knowledge of machine work, but I'm looking for a manufacturer who can make hardened steel plates which have the texture of a file on one side and measure 5 in. wide by 8 in. long and are .50 thick. I'd appreciate any help you could offer. I already have prototypes made. Thanks, Russ
Old 10-21-2007, 07:47 AM
AMW's Avatar
AMW AMW is offline
AMW is on a distinguished road
Hello Russ, will you be using these plates for "LAPPING?"
Regards
AMW
Old 10-21-2007, 08:55 PM
To AMW
Thanks for replying; I'm not familiar with the term: "lapping".
I need to find a mfr. who can produce 5"x8" hardened steel plates which have a file like surface on one side and are perfectly flat on the other.
I was told that there was a way to cast the piece with the file edges in in and sharpen the "teeth" by running a stone wheel over them. Are you familiar with this process?
I appreciate any help.
Russ
Surfacing Steel Plate Hibo Tormach PCNC 2 10-22-2007 12:55 AM
Seeking Drilling Parameters for Stainless Steel 401 hallowed General Metalwork Discussion 10 09-30-2007 03:34 AM
RFQ - on 1/2" mild steel plate BullCreek Employment Opportunity 5 07-10-2006 06:31 PM
Notching Steel Plate bb99 Welding, Brazing, Soldering, Sealing 3 10-13-2005 07:31 PM
Cutting 3/8 steel plate BlueC General Metalwork Discussion 2 05-21-2004 10:06 PM
