Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 10-11-2007, 02:30 PM
LMRecruiter is on a distinguished road
Cool Optical Operators Needed in Orlando, FL
Lockheed Martin in Orlando, FL currently has 7 Optical Fabricator / Optical Operator positions open. If you're interested please send your resume to stacie.merker@lmco.com
Job description:
Specific Job Description Polish various types of micro-optical to maxi optical elements to specified optical specifications. Rough and finish grind all types of optical elements. Sets up and operated vacuum coating equipment to perform a wide variety of coating processes, sets up and operates a wide variety of CNC machines to cut and shape blanks for optical elements. Diamond Turns (CNC all types of optical elements and optical mounting surfaces to specified requirements. Need to be able to pass the Pre Employment Physical exam. Minimum high school education or equivalent desirable. Should possess the ability to be granted a secret clearance.
Required Skills:
Diamond turns optical elements, Diamond turns mounting surface, Rough and finish grind, CNC/conventional, polish micro-optical, maxi optical elements, Operate CNC and manual, vacuum coating equipment
Desired Skills:
Prior optical fab and coating
Required skills: Polish, grind optical elem, diamond turning , vacuum coating , generate optical elements, prior Optical fab exp., ability to read English
Desired skills: AS degree in Optics, math skills
* This is a full time position. 9/80 work week (every other Friday off). Great benefits!!!!!
Thanks,
Stacie Merker
Recruiter
Orlando Regional Recruiting Center
Rockford IL - CNC Operators Needed dcantin58 Employment Opportunity 0 08-23-2006 04:40 PM
Experienced Operators & Programmer Needed -TN StacyE Employment Opportunity 0 06-14-2006 04:26 PM
CNC Operators Needed in Westfield, IN Stacy Employment Opportunity 0 06-06-2006 09:56 AM
CNC Set-up and Operators needed in the Baltimore, MD Area Daniel Belove Employment Opportunity 0 11-01-2005 12:05 PM
programmers/operators needed! bradgcs Employment Opportunity 4 09-06-2005 09:54 PM
