Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 10-08-2007, 02:44 PM
DrStein99's Avatar
DrStein99 is on a distinguished road
Hire a machine shop to make surface plates
I am looking for a machine shop to do some machining on steel. Squaring, surface milling, etc...
I'm re/designing my garage-made cnc machine, each axis at a time. In the past, I would do this work myself, but now I feel I want these structures made from steel, and I do not have the equipment to do this work on pieces. I feel the basic square plate designs with bolt patterns would be simple and easy for someone who had the right machinery.
Sizes are roughly 24" x 30" x 1" for part #1 and 12" x 16" x 1" for part #2)
Basically, these would be the plates that I bolt my linear rails and ballscrews to. A plate on the bottom and plate on the top. I would create a mechanical drawing.
So I was wondering if anyone had advice for shops I can call for some quotes, or links to websites? Any input on their experiences and what to lookout for?
WWW.RAIDGEAR.NET - FFC cables, foam headset replacement parts, and other gadgets.
Old 10-08-2007, 03:37 PM
harryn is on a distinguished road
There is an rfq section in this forum.
Old 10-09-2007, 03:25 AM
svenakela is on a distinguished road
I moved it.
Use Machine Shop vs. Buying Machine imp22b General Metalwork Discussion 15 06-06-2007 07:33 AM
Man Vs Machine (Do You recon you could make one?) ynneb CNCzone Club House 11 05-31-2007 08:00 PM
what machine would I need to make this cut? steve knight Commercial CNC Wood Routers 7 08-12-2006 04:30 PM
Experienced CNC Machinist, Programmer, and designer... Services for hire Steeda31505 Employment Opportunity 0 05-10-2006 04:18 PM
How to make Parallel Square Beam/pipe without flat surface ? Calico Welding, Brazing, Soldering, Sealing 8 06-26-2005 09:13 PM
