Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 10-02-2007, 06:00 PM
GNS GNS is offline
GNS is on a distinguished road
Laser Cut / WaterJet Mild Steel Parts
Can anyone please provide quotes for the attached file? Ideally laser cut or waterjet cut although I suppose it could be done on a machining centre.
The specs of the material are:
Mild Steel (Grade unimportant) 1.5mm Thick, tolerances +/- 0.25mm
Please provide quotes for quantities: 1 Piece, 5 Pieces, 10 Pieces, 50 Pieces, 100 Pieces and 1000 Pieces.
This is basically a job that has come in to our shop that for me is going to be more aggravation than its worth, mainly as we don't really do any sheet metal work - its pretty much all machined billet.
Please be aware we're based in the UK.
Many Thanks.
Cutting 1" Mild Steel 3DSteve CNC Plasma and Waterjet Machines 14 06-14-2007 05:58 AM
Mild Steel MBG General Metalwork Discussion 1 03-09-2007 05:20 PM
RFQ: Milling needed in mild steel. SCCoupe Employment Opportunity 2 12-10-2006 09:06 PM
RFQ - small mild steel turned and drilled parts mcmmach Employment Opportunity 8 07-28-2005 10:37 PM
Machining Mild Steel georgebarr General Metal Working Machines 5 06-29-2005 07:54 PM
