Results 1 to 3 of 3
Thread: CNC Machinists II - 3 positions!!
    Oct 2006
    Post CNC Machinists II - 3 positions!!
    Operate CNC machining equipment, including set-up, adjustment, and tool change to produce parts of moderate to high complexity meeting documented specifications. Perform dimensional measurements to ensure compliance with manufacturing specifications. Document inspection results. Prepare tooling and/or fixtures for setups in advance by organizing and maintaining, "setup kits" for issued work orders.
    PHYSICAL DEMANDS
    Must occasionally be able to lift and/or move up to 65 pounds. Specific vision abilities required by this position, include close vision, depth perception, and the ability to adjust focus. Mechanical abilities include eye-hand coordination, and sufficient hand strength to assemble products.
    WORK ENVIRONMENT
    While performing the duties of this position, the employee routinely works near moving mechanical parts, and is exposed to fumes or airborne particles, toxic or caustic chemicals, and vibration. The noise level in the work environment is usually moderate.
    (3) three positions (Machinists II)
    The starting salary is $14 - $19 based on experience.
    The 1st shift, one needed for Monday-Friday (8 hour days)
    The 2nd shift, two needed has a 10 % shift differential on top of the base hourly rate and the hours are:
    Monday-Thursday (10 hour days).
    Please have any candidates send resumes and or call Ken Wanner at 561-207-6764
    Registered dmealer's Avatar
    Oct 2004
    Would be nice to know the location!!!
    Aug 2007
    Harrison AR USA
    It reverse lookups to West Palm Beach FL. - a headhunter co.
    Ōz@®KÇÑÇ
  1. CNC Setup positions available in SC
    By Zbuilder in forum Employment Opportunity
    Last Post: 08-02-2007, 07:17 PM
  2. Multiple Positions Available -TN
    By StacyE in forum Employment Opportunity
    Last Post: 04-19-2007, 01:02 PM
  3. The State of CNC Positions
    By ViperTX in forum CNCzone Club House
    Last Post: 09-08-2006, 11:32 PM
  4. Open Positions
    By StarCatcher in forum Employment Opportunity
    Last Post: 07-16-2006, 04:51 PM
  5. Reference positions in DIY CNC
    By davidp in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 05-23-2006, 03:48 PM
