Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 05-21-2004, 01:26 AM
hhiibel is on a distinguished road
need qoute for 2 of this.
needs to be 6061.
hopefully the attachment works.
if not i can email it.
it's pretty close to what i need.
i'll supply a mock up.
or i'll settle for the .gif without the 4 smaller holes or the notch in the big hole.
i had someone else do this and they switched the thick and thin on the side veiw.
howard hiibel
415 732 2534
Old 05-21-2004, 01:59 AM
detail1
detail of image
Old 05-21-2004, 02:01 AM
detail view 2
closer view more
Old 05-21-2004, 02:02 AM
and more
more explosion of initial image
Old 05-21-2004, 02:05 AM
so that's it. the last one is the side view of the next prior image. and that's what the first guy switched. so give me a quote.
howardshari@comcast.net
howard.hiibel@mckesson.com
415 732 2534
thanks.
Old 05-21-2004, 11:58 AM
HomeCNC's Avatar
HomeCNC is on a distinguished road
Howard,
Glad you found the group. I don't have anytime available to make parts but I'm sure someone here will give you a quote.
Howard, You should post the full picture with the views in the proper place like you sent me. With the views all seperate it makes it harder to follow what you want.
I just made a fast model in SolidWorks
Jeff Davis (HomeCNC)
http://www.homecnc.info
Old 05-22-2004, 12:51 AM
Jeff,
That little teenie picture on the first post is what i sent you.
And I'm lucky to have done that.
If anyone want's a big version just email me.
I really need this part.
Thanks,
Old 05-22-2004, 10:37 PM
thanks to cnczone.
a member is making the parts.
Old 06-04-2004, 09:52 PM
Gold Member
Ken_Shea is on a distinguished road
Hi Howard,
Received your check, thank you.
Were they OK for you?
Ken
Old 07-31-2010, 01:59 AM
yes. thanks
ken,
sorry for the very late reply. i came back to this post because a member at www.fordfe.com is looking for wedges only. he may be contacting you.
howard
