Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 09-25-2007, 12:17 PM
Armis's Avatar
Armis is on a distinguished road
Request For Quote For Wood Board Game Pieces
We are in need of a price quote for wood game pieces for the board game called Armis.
Our immediate need is for 100 sets (36 pieces per set).
Photos of most of the game pieces can be seen here: http://docs.google.com/Doc?id=dgssv9cs_68f4j4p8
As you may see, changes were made to some game pieces (eg: copter/jet) so that they can be made easier with your CNC machines.
We are open to all questions ...
Lastly, please submit a lead time you can honor, and provide a bid in USD not hours. This bid request will officially close on October 5, thanks for your attention.
Old 09-25-2007, 12:42 PM
dpryor is on a distinguished road
What kind of finish are you going to require on the wood pieces? While the geometry is faily simple, it may be a rather complex CNC operation. Do they need to be wood? Have you considered cast urethane?
Doug Pryor
David Wolfe Design, Inc.
Akron, OH
www.davidwolfedesign.com
depryor@davidwolfedesign.com
Old 09-25-2007, 01:09 PM
Armis's Avatar
Dpryor, thanks for your speedy reply; on your first point, the pieces need not be finished.
With regard to the second point, although we are open to any material (wood, stone, clay, urethane (is that plastic?),) we figured wood would generate us a very good looking product, a very fast turnaround, low upfront costs, and a very durable product.
Plastic injection molding will eventually be one whole aspect of the game's production, however only after we have gauaged market demand on a few levels.
We would welcome your quote for this job in 'urethane'.
Old 09-28-2007, 09:12 PM
Armis's Avatar
Ok, I'm approximately half way through my time deadline for this quote, I see about 150 thread view, 45 pdf views, and 1 reply but not one quote ... please let me know where the problem is?
Old 09-28-2007, 09:27 PM
ger21's Avatar
Imo, it would be very expensive to get those made out of wood. Perhaps that is why you haven't got any quotes.
Old 09-28-2007, 09:47 PM
Armis's Avatar
oh ... ok
... uh ... about how much would "very expensive" be (ball park)?
Old 09-28-2007, 09:56 PM
ger21's Avatar
I don't see enough information in your .pdf to even guess. You should post some detailed, dimensioned drawings of all your parts.
Old 09-28-2007, 11:03 PM
Armis's Avatar
I've edited the initial post with a different drawing, this one includes dimensions for all pieces.
We tried to make it as simple as can be, if this drawing was printed as layed-out the pieces would be the size we expect.
If there is a set of file extensions that are most desirable for the bidder please let me know and I will try to provide the file with one of those extensions.
Old 09-29-2007, 02:01 AM
Moondog is on a distinguished road
Armis.
Instead of Solid Timber, would you consider a Marine or similar Plywood?.....
With your designs there are a lot of sharp corners/angles that would require several passes. Are radiused corner/s acceptable?..
cheers
Frans
Old 09-29-2007, 10:08 AM
turmite is on a distinguished road
Armis I tried opening the pdf in my 3d cad (Rhino) and it said unknown op.
Do you have these in a cad system? I don't know about everyone else, but I personally hate anything pdf! The only way I could quote on these would be to do a screen shot, import that into Rhino and then have to model each one individually. I promise you that you don't want people having to re-model or re-draft what you have already done.
To reinforce what has already been said......all the sharpe inside corners are going to make this a very expensive process, and quite honestly will keep people from bidding.
With the current rfq the only way I could bid on it would be a per hr price because I don't know how long it is going to take to re-draw everything.
Mike
No greater love can a man have than this, that he give his life for a friend.
Old 09-29-2007, 11:28 AM
HuFlungDung's Avatar
Moderator
If these are simple 2d shapes extruded in 3d, then I suggest that you submit a set of line drawings to a waterjet outfit. They can process wood, can cut sharp corners, etc., etc.
  #12   Ban this user!
Old 09-29-2007, 04:34 PM
kdoney is on a distinguished road
You show lines in front of the outline of the drawings. This seems to me to be 2 (or more) levels of cutting. Is this what you want?
Pre-RFP Information Request For Game Piece Work Armis WoodWorking 11 09-25-2007 07:53 PM
Request for quote Hasher General Electronics Discussion 1 07-21-2006 10:50 AM
Request for quote mike562 Employment Opportunity 5 04-03-2006 02:38 AM
Request for Quote-Casting Parts emiljbd Employment Opportunity 2 07-14-2005 02:20 PM
Request Quote smattstone Employment Opportunity 2 06-28-2005 07:49 AM
