Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 09-25-2007, 12:27 AM
Gledhill is on a distinguished road
Plasma Cutting needed
I need 50 of these brackets plasma burned out, I have attached the file as a dxf. I am not worried about the tolerances if you can hold .100" that is fine and the parts do not need to be debured or cleaned up. Please quote including material and not including material. These need to be burned out of 3/8" standard A-36 steel nothing fancy. Feel free to email me at tylergledhill@hotmail.com
In the past I have burned these out at 100amps at 80ipm. Not including the lead in the outside parameter is 21.695" giving a cutout time of around 18 seconds per part. This seemed to produce a very good part but whatever you normally run 3/8” at is fine.
I have been working on getting my own table going but haven’t had time thanks.
Plasma cutting setup?? jlenelms CNC Plasma and Waterjet Machines 2 08-15-2006 10:42 PM
Looking for some Plasma Cutting ArcadEd Employment Opportunity 4 05-09-2006 09:26 AM
Plasma cutting mdf. ynneb CNC Plasma and Waterjet Machines 8 11-05-2004 08:56 PM
plasma cutting? anyone using it? rmacguiver CNC Plasma and Waterjet Machines 11 11-05-2004 09:31 AM
Mastercam and CNC PLasma Cutting comanche1 Mastercam 4 06-04-2003 01:26 AM
