Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 09-17-2007, 09:43 PM
davea5025 is on a distinguished road
RFQ: Aluminum Turning and Milling
Looking for a quote for a total of 6 pieces, 2 each of 3 types.
FacePlate2.dxf is attached.
Cylinder1.jpg is attached. DXF was over 500K, so could not attach it. Will send to anyone requesting. No idea why it was so large.
The third part type is a timing pulley (qty 2) which needs to have the center bored out to a radius of 1.18 inches to fit on cylinder. I have these pulleys on hand and expect to send them to whoever is doing the work. They are Stock Drive Products PN A 6A 3-20DF03708.
Assume you will acquire stock for other pieces unless quoted otherwise.
Thanks,
Dave.
Old 09-18-2007, 08:31 AM
jetski is on a distinguished road
We do alot of alum machining. 6061 aircraft grade. Please send me a drawing I opened the drawing but nothing came through. My autocad is an old version 2000 may be non compatable or something. Send the files to gsilberberg@progressive-plastics.net
Thank you
Old 09-18-2007, 04:19 PM
Gary Holliday is on a distinguished road
Waterjet Cutting and Other
I have a brand new waterjet cutter. Send the drawing to me at misterpcus@yahoo.com with anything else that's applicable. I'll look at it and let you know what we can do.
Gary
Old 09-18-2007, 07:30 PM
jjasshipley is on a distinguished road
Prints
I could import the files, but your "solids" were wireframe only. Was this in Autocad? I couldn't open in 2000. Could you please email files to jjasshipley@insightbb.com I can accept other file types as well if you have them. Thanks for the opportunity
Old 09-18-2007, 09:14 PM
Square Tech is on a distinguished road
Turning and Milling
You have a p.m.
Thanks,
Steve
Old 09-20-2007, 08:31 AM
RedGTZ's Avatar
RedGTZ is on a distinguished road
please send files to redgtz@hotmail.com
Thank you!
Old 09-20-2007, 11:10 AM
Philip is on a distinguished road
PM sent
PM sent.
Philip Confalone
Machining Concepts
Old 09-20-2007, 01:03 PM
Twil759 is on a distinguished road
Could you send files to twilson@ymsinc.net? Would like to quote.
Aluminum (turning/milling) impact Employment Opportunity 5 06-27-2007 03:39 PM
RFQ: aluminum milling and steel turning stanglou Employment Opportunity 2 01-21-2007 09:09 PM
aluminum turning RFQ camarogod98 Employment Opportunity 0 01-04-2007 03:12 PM
RFQ: Aluminum Turning Nova9911 Employment Opportunity 7 11-18-2006 06:27 PM
Turning Aluminum 6061-T6 Machine1 Hard and High Speed Machining 3 09-11-2003 01:04 PM
