Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 08-24-2007, 04:46 PM
dsmdude is on a distinguished road
RFQ: Turn / Mill work needed 2" dia 1018
I need qty 2 of these to start with out of 1018 CR steel for prototype purposes. Tolerances are .003" which should be easy to do. We will eventully bring this part in to production pending costs and slight design changes, ordering aprox 30-60 of these at a time every 2 months. I checked on material costs to give a rough idea I was quoted $6.84 a foot. Need a quote with you supplying the material, time frame, payment method, etc. We will close this quote on August 30, 2007.
Note: I'm not quite too sure how to post the 3d ipt file on here. I can also get you this file in auto cad dxf if required. Please let me know your email address if interested and I can email you the files. The aprox length of the part is 9.13" and major diameter of the solid is 2". The milling / drilling operations on the end with the threads does not need to be indexed any specific way in relation to the milled flat surfaces on the other end. Thanks!
Name:	bearing shaft threaded view 1.jpg‎
ID:	42602   Click image for larger version
Name:	bearing shaft threaded view 2.jpg‎
Old 08-24-2007, 08:23 PM
AMW's Avatar
AMW AMW is offline
AMW is on a distinguished road
Hello, we have sent you a PM with our contact info!
Please e-mail us your files.
Thank you in advance for the opportunity to bid on your RFQ
Regards
AMW
Old 09-26-2007, 12:10 PM
Thank you to Specialized Machine out of Souix Falls, South Dakota. They did an awsome job on our parts and were very professional through out the entire process. Thanks again!
Old 09-26-2007, 12:53 PM
WILLwork4money's Avatar
WILLwork4money is an unknown quantity at this point
The last post before this one of yours was a month ago, It'd been PROFESSIONAL to inform everyone that the job had been awarded!!
WILLwork4money
Old 09-26-2007, 04:56 PM
.....quote with you supplying the material, time frame, payment method, etc. We will close this quote on August 30, 2007.
Old 09-26-2007, 06:04 PM
AMW's Avatar
AMW AMW is offline
Is this RFQ still open?
> On today's post @ 8:10 am you say that Specialized Machine out of Souix Falls, South Dakota did an awsome job on your parts and on today's post @ 12:56 pm you say We will close this quote on August 30, 2007.
>> Are you looking for quotes on 30 and 60 pieces?
Please advise, and if it is still open, would you be so kind as to email us your files to applied.machineworks@yahoo.com
I look forward to hearing from you!
Regards could you also give me your steel source? I haven't found anyone that comes close to your material cost per foot!
AMW
Old 09-27-2007, 10:59 AM
Sorry this job has been awarded. The steel price was a quote from a local steel yard (we are in central Minnesota) no special pricing. We will be doing more RFQ in the near future and will keep the board updated. Thanks for all who participated in the bid.
RFQ - milling work on 1/4" wide tool steel - may need azis mill or right-angle mill pendentive Employment Opportunity 7 01-21-2007 08:56 PM
question on ability to turn a 18" piece of work on a hf 9x20 lathe vha27 Mini Lathe 3 12-23-2006 10:41 PM
RFQ - Simple Aluminum Work, Fast Turn-Around. - AWARDED - JavaDog Employment Opportunity 6 11-17-2005 03:25 PM
