| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
Hi. I need a quote preferably from someone in the southern ontario area for some CNC machining work. this is one part of a couple similar parts and also some aluminum CNC turning could also be sent out for quote. This part is just cheap hot rolled steel that I normally buy as 2" x 1" flat bar. The qty would be 20, 50, 100, 500 for pricing. I would probably take a lower qty as my first order and then increase it to either 100 or 500 pcs. Thank you. EDIT* I put the wrong file in the post, please read my post below with an explanation, Sorry Last edited by rubberdown; 08-20-2007 at 03:54 PM. |
| Maybe I am missing something? Your dxf appears to be a part that is 3.225 diameter. Please clarify Feel free to email me if you wish.
| Sorry guys, my bad, that is a 6061 aluminum round part that you are free to quote as well, it is currently being turned in 2 operations out of 3-1/4" round 6061 aluminum. The finish needs to be decent as far as appearance goes, but thats about it, it too is pretty much +/- 0.010" everywhere as well. These I would need a quote on 10, and 100 pcs at a time, you supply the material. The 10 would just be to see the quality I guess, then if its all good, it would be 100 per order with repeats as needed. I need it to be 6061 aluminum because ut seems to be the proper grade for anodizing different colors. I'll put up the proper DXF file for the steel milling machined part when I am at work on Monday morning. Sorry for the mistake. |
| Heres the steel part in a DXF file, In the file, it is pictured the way we are currently having it made, as a set of 4 parts to save tool change time and then they get cut to the proper length in the manual saw and then the last machining operation is done which is the channel in the center of the top of the part. All edges to be de-burred with something like a belt sander, we do most of the edges in the cycle with a 45 degree fly cutter to eliminate hand work on them. Last edited by rubberdown; 08-20-2007 at 03:54 PM. |
#12
| Rubber There is enough info to quote these jobs. However, both of your DXFs do not have dimensions lines or extension lines. This will create some guess work for the company trying to machine them. There are dimensions hovering around the print though.
| 3-D Machining | rweatherly | Mach Software (ArtSoft software) | 27 | 12-24-2009 03:14 PM |
| Machining anodized parts or anodize after machining? | SRT Mike | General Metalwork Discussion | 4 | 03-12-2006 12:22 AM |
| Machining Help! | Al_The_Man | General Metalwork Discussion | 7 | 11-12-2005 04:15 PM |
| cnc machining | fastolds | Employment Opportunity | 0 | 03-29-2005 03:37 AM |
| One Hit Machining | CRPDGAZ | Hard and High Speed Machining | 10 | 03-24-2004 02:52 AM |
