Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 08-16-2007, 03:42 PM
stanglou is on a distinguished road
RFQ: 1020 lathe work
three seperate pieces need quoting. short runs of 10 pieces each. we are currently getting each piece for $4. can you beat it?
Louie
louie@gmachineracing.com
562-595-5410
Old 08-16-2007, 04:15 PM
skmetal7 is on a distinguished road
tolerances?
Old 08-16-2007, 04:45 PM
you could use 1.25" stock and just machine the length and innher taper on this one. inner taper would be nice at +- .001
Old 08-16-2007, 05:03 PM
do u have a material vendor that has 1020? im having a hard time finding this (I looked at speedy metals and mcmaster carr). could this be made out of 1018 instead?
Old 08-16-2007, 07:32 PM
most metal houses carry 1018/1020 steel standard. you can quote for 4130 if you would like.
Dahlih MCV 1020 Fanuc 10m burbankbrewer General CNC (Mill and Lathe) Control Software (NC) 2 06-10-2008 08:10 AM
Dahlih MCV 1020 Fanuc 10m burbankbrewer CNCzone Club House 0 11-15-2006 11:44 AM
Need more work for cnc lathe R&B General Metalwork Discussion 7 10-15-2006 11:53 AM
CNC lathe work Crazy Phantom Employment Opportunity 8 02-05-2006 11:42 PM
Machining 1020 Steel with Inserted Cutter Machine1 Hard and High Speed Machining 6 01-26-2004 09:26 AM
