Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 08-01-2007, 09:41 AM
chris9911 is on a distinguished road
RFQ - small aluminum bracket
Here are list of features:
1. rough stock size is 3.75" x 2.25" x .5"
2. 2x 6.4mm clearance holes
3. 2x M6x1 tapped hole
4. 1x M5x.8 tapped hole
5. 1x slot
6. outer profile
7. machine top and bottom surfaces.
Aybody with a small milling machine can do this. Quantity will depend on the price.
Old 08-01-2007, 10:17 AM
I need a quote with and without the three threaded tapped holes.
Old 08-01-2007, 10:19 AM
ddprecision is on a distinguished road
Drawing? Without a drawing there are too many questions left unanswered. If you want an accurate quote provide a drawing.
Old 08-01-2007, 10:24 AM
chipmaker6 is on a distinguished road
could you fax a print to me at (580-234-1687)
we have a hurco vm3
Old 08-01-2007, 10:29 AM
AMW's Avatar
AMW AMW is offline
AMW is on a distinguished road
How wide is the slot, length and depth and are the tapped holes through?
Please advise either in this forum or by contacting us via e-mail to:
applied.machineworks@yahoo.com
Regards
AMW
Old 08-01-2007, 11:02 AM
Provide me with a fax number and I will send it over. Chipmaker6, the drawing is on it's way. Please ignore all the GT&T and tolerances. The drawing acutally looks more intimitaing than it really is. It doesn't need to meet all those details. I could care less if this part was made with a hacksaw, drill, and a dremel tool
I can send a dxf file in 1:1 scale. You can then glue the template on to the aluminum block and just cut out the shape. I'm thinking this will probably be the cheapest way to make this part.
The slot is trianglular, with generous radius on the 3 corners. a=(1.2") b=(.5") c= (1.25")
All the holes and slot are thru.
I'm looking for quantity of 1 to start and then up to 100, after the fitment check.
Old 08-01-2007, 11:12 AM
chipmaker, I just faxed you 1:1 scale print
Old 08-01-2007, 11:23 AM
manuelc149 is on a distinguished road
drawing?
can u post or email a drawing?
Old 08-01-2007, 11:24 AM
larry53 is on a distinguished road
Aluminum bracket
5. 1x slot
6. outer profile
I would need some more imformation in order to quote, such as outer profile,top and bottom machine surfaces and hole location.
Old 08-01-2007, 11:29 AM
I will send the print out to a fax machine. Please ignore all the GD&T, it makes the part look lot more intimidating than it really is. I could care less if you used a hacksaw, drill, and a dremel tool to make this
The slot is trianglular with generous radius on all three corners. a=(1") b=(.5") c=(1.125") All the holes and slot are thru-all.
If you have a manual mill, I can send you a drawing in 1:1 scale. You can then cut it out and glue it onto the aluminum block to mill it. Maybe this will be the cheapest way to make this part.
I'm looking at quantity of 1 to use for a fittment check. I will then probably need up to 100 afterwards.
  #11   Ban this user!
Old 08-01-2007, 11:35 AM
I don't want to make the drawing public. Please give me your fax machine and I will send it over immediately.
  #12   Ban this user!
Old 08-01-2007, 11:48 AM
i cant read your number on the fax you sent
RFQ - Aluminum Parts - small job F500 Employment Opportunity 8 06-08-2007 03:30 PM
Request Closed: Small Aluminum CNC Job gravydrive Employment Opportunity 6 05-30-2007 10:47 AM
Need some aluminum bracket help sin-city-custom Employment Opportunity 5 08-08-2005 07:05 AM
contouring aluminum with small bit corpse Benchtop Machines 6 09-14-2004 01:11 PM
Bending small aluminum rod Twmaster Bending, Forging,Extrusion... 9 08-06-2004 07:50 PM
