Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 07-29-2007, 06:51 PM
kdoney is on a distinguished road
Simple SS 304 Plate
I need the part in the attached drawing made out of 304 Stainless. I need this part as soon as possible so please include surcharges for rush jobs. You supply the material 5.5 X 4.5 X .5. Face and obverse needs to be machined flat within tolerance of +- .001. All other features can be +- .002.
If you need another file type just let me know. I don't have the facilities for pdf file generation.
Old 07-29-2007, 07:39 PM
AMW's Avatar
AMW AMW is offline
AMW is on a distinguished road
.dxf file note
Hello, thank you for the opportunity to quote your job!
*Your .dxf file carries the following note: .175"Ø thru w/.275" C' Sink .150" deep
Q1: Is the .275" C' Sink .150" deep really supposed to be a C' Bore -vs- a C'sink?
Q2: Is this RFQ for one piece only as it implies?
>> Please advise<<
Regards
AMW
Old 07-30-2007, 07:26 AM
Yes, it is a counter-bore and it is for one piece. One addition, all sides need to be milled flat to within +-.001.
Kevin
Old 07-31-2007, 02:23 PM
manuelc149 is on a distinguished road
gone?
has some one taken the job yet? i got material and can start asap.
Old 07-31-2007, 08:39 PM
No, I just got the first bid.
Please Help!! Simple 3-D part not so simple for me eaglegage Mastercam 16 05-15-2008 10:00 AM
Aluminum: flat, bar, sheet, plate, tooling plate?????????? Dan S DIY-CNC Router Table Machines 12 06-28-2007 12:48 AM
410 & 420 SS plate AMCjeepCJ Mass finishing equipment/media/stratigies 0 03-31-2006 10:09 PM
Simple Question Simple Answer ? p3t3rv Stepper Motors and Drives 6 02-16-2006 09:00 AM
Tooling plate or sub-plate drill General CNC (Mill and Lathe) Control Software (NC) 3 02-02-2006 02:17 PM
