Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 07-18-2007, 03:46 PM
S V R E is on a distinguished road
RFQ: NHRA Pro Stock head simi finishing
Need to have some NHRA Pro Stock heads simi finished. These heads are unmachine cores that need to have all the surfaces , valve guide, bolt holes,and dowel holes machined and tapped. Need to be a 5 axis machine to do the spark plug holes and the intake valve guide hole. (they are canted)
This is low quantity as of right now, but could be high volume in time.
Steve Vance
704-701-4235
Steve Vance Racing Engines
Old 07-21-2007, 07:48 PM
svp svp is offline
svp is on a distinguished road
Steve, what is your time-frame, and what exactly do you consider low-quantity?
Steve H
SVP
Old 07-21-2007, 07:50 PM
svp svp is offline
Steve H
SVP
Old 07-22-2007, 08:44 PM
Time is not a big deal. As of right now, I will just need one set to get started. After that, if all goes well, it will be about 10 set at a time.
Steve
Old 07-23-2007, 09:12 AM
svp svp is offline
Can you send me a drawing of what you need cut? I take it you want all but the final port configs?
Call me at 831-422-2484, and we can discuss.
Steve
True Head stock frankg521 Mechanical Calculations/Engineering Design 6 11-27-2006 07:19 PM
Finishing welds itsme Welding, Brazing, Soldering, Sealing 6 09-14-2005 01:45 PM
MDF Finishing Question The Wizard DIY-CNC Router Table Machines 3 10-31-2004 10:29 PM
finishing pine alarants WoodWorking 10 10-25-2004 03:21 AM
head stock and tail stock chucks mocnc DIY-CNC Router Table Machines 3 10-19-2004 09:16 PM
