Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 07-16-2007, 06:43 PM
joey_hv is on a distinguished road
RFQ: Diving helmet, aluminum, bronze or delrin:JOB FILLED
Hello,
I do not have the capabilities to make drawings of this helmet that I need fabricated. I can email pictures of the plug I have made.
I thought I would check out the possibilty of having these shells cut out by CNC before I commited to having a fiberglass mold made for fiberglass production.
The helmet measures app. 12"x 12" x 12"
and it needs to be hollowed out, The inside of the lower front area does not need to conform to the exterior shape but can just be flat. The thickness of the shell can be 1/8" except the front face plate and mouth/nose areas, these need to be 1/4" thick.
These helmets will be used in an underwater marine environment. If you are able to quote me a reasonable price I will send you the helmet plug and any required down payment.
Please quote me on the following seperately for each material:
1 set of cad drawings
5, 10 & 15 shells cut out of black Delrin
5, 10 & 15 shells cut out of marine grade Aluminum
5, 10 & 15 shells cut out of Bronze
thank you
Joseph Velderrain
602-301-4116
Old 07-17-2007, 09:30 AM
WOLOG's Avatar
WOLOG is on a distinguished road
Can you post the drawings?
Old 07-17-2007, 10:29 AM
AMW's Avatar
AMW AMW is offline
AMW is on a distinguished road
WOLOG, he stated he doesn't have Drawings, he is asking for quote for Drawings and manufacturing cost But a nice picture would do fine for visuals in my case!
AMW
Delrin vrs Bronze bushings BoxGods Linear and Rotary Motion 6 02-28-2007 11:51 PM
Aluminum & Bronze Castings foundry Casting Metals 1 02-12-2007 07:52 PM
Machining Aluminum Bronze home-tek General Material Machining Solutions 8 12-29-2006 11:06 PM
Machining Aluminum Bronze clayman General Metalwork Discussion 4 12-11-2006 09:03 AM
.5 Mod Delrin or Aluminum Spur Gears Crazy Phantom Employment Opportunity 0 01-09-2006 05:40 PM
