Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 07-11-2007, 01:01 PM
schiada96 is on a distinguished road
RFQ cast aluminum tooing plate job (closed 7-16-07)
Please quote 50 pcs. QMF will supply blanks 26" x 51".
Sheet 4 and 5 are not included and I will supply if you are interested
in quoting.
I do not have cad files for this part.
Questions
Please call
Jeff Barton
QMF Solutions
Kernersville
North Carolina
27284
336-996-5570
jbarton@qmf-usa.com
Old 07-11-2007, 01:10 PM
Here is page 3 and 4 and yes I can't spell "tooling"
Old 07-12-2007, 06:22 AM
AMW's Avatar
AMW AMW is offline
AMW is on a distinguished road
Pages 3&4 are the same as the first 2, ie: SDOC2030.pdf contains the same files as SDOC2031.dxf, furthermore, your prints are incomplete for manufacturing purposes, missing dimensions such as actual width and length, "Radii dimensions""Angles" so on and so forth!
please email us your complete drawings to applied.machineworks@yahoo.com
We look forward to working with you
regards
AMW
Old 07-12-2007, 06:50 AM
AMW
I believe it's all there.
Sheets 1 thru 3 SDOC2030 sheets 4 & 5 SDOC2031
The print calls out vitural sharp points for the radi and hard
dimensions. See sheet one. I agree the engineer could have done better with these prints.
Jeff
Old 07-16-2007, 01:17 PM
RFQ closed.
Need a source for cast iron plate bgolash General Material Machining Solutions 11 11-27-2010 03:45 AM
T-slot table vs. cast plate ddgman2001 80/20, TSLOTS and other Aluminum Framing Systems 4 05-27-2008 11:42 PM
Aluminum: flat, bar, sheet, plate, tooling plate?????????? Dan S DIY-CNC Router Table Machines 12 06-28-2007 12:48 AM
Determining Cast Zinc from Aluminum lwhiway General Metalwork Discussion 6 11-21-2006 08:04 PM
Cast aluminum Runners and Plenum Kmed Employment Opportunity 3 08-30-2005 11:35 PM
