Results 1 to 1 of 1
Thread: .125 thick material quote on waterjet or laser cut
    Jun 2007
    I would like to get some quotes on the following attached file. I would like to have a quote for total of 8 parts there are 4 parts in the file but thats right side left side top and bottom. so i need 2 right, 2 left, 2 top, 2 bottom.
    I would like a quote in both brass material and aluminum material at .125 thickness. and an internal radius is allowed for the corners
    thanks
    quotes can be e-mailed to timber_cutter2002@yahoo.com
    Attached Files Attached Files
  1. Cutting thick steel plate
    By Woodenspoke in forum General Metalwork Discussion
    Last Post: 07-12-2007, 12:58 AM
  2. NEwbie Help, is this too thick for my TIG ?
    By Calico in forum Welding, Brazing, Soldering, Sealing
    Last Post: 09-29-2005, 07:16 PM
  3. Cnc Machining 1/8 thick steel sheets
    By ccm in forum General Metal Working Machines
    Last Post: 10-28-2004, 03:47 PM
  4. 1/2 thick gantry ends..is it strong enough?
    By bgolash in forum DIY CNC Router Table Machines
    Last Post: 10-05-2004, 09:19 PM
  5. How thick is too thick?
    By lookalion in forum General Metal Working Machines
    Last Post: 08-30-2004, 03:08 AM
