Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 07-06-2007, 10:30 AM
slick_rick is on a distinguished road
RFQ: Circle segments
I'm looking for someone to mill a pair of circle segments (chords?) for me. I could supply a drawing, but I think it is overkill considering how simple the parts are. If you can imagine taking a circle then slicing off the top 2.89 inches or so, that is what I need. I need two circle segments, one cut from a 26.38" radius circle, and the second cut from a 12.74" radius circle. The 26.38" circle segment will end up being 24" wide and the other 16.15". I'd like them made out of 1/8" aluminum that the shop supplies. This isn't a prototype or anything, just a set of templates I'll use for my router for woodworking, so it is likely to be a one-time job though I may end up wanting different sized templates later on.
The following image may shed some light, I'm interested in the yellow portion of the image where h would be 2.89 for both, and c would be 24 where R is 26.38 and 16.15 where R is 12.74.
http://mathworld.wolfram.com/images/...gment_1001.gif
Thanks for looking...
Old 07-06-2007, 11:32 AM
manuelc149 is on a distinguished road
email to send quote to please.
Old 07-06-2007, 12:21 PM
Email
You can PM me the quote or send them here:
richard {dot} rowell {that andpersand thingy} gmail.com
Thanks!
Old 07-06-2007, 12:32 PM
Gold Member
lerman is on a distinguished road
You might want to say that it is OK to have a few holes in the segments to hold them down while they are being machined.
Ken
Kenneth Lerman
55 Main Street
Newtown, CT 06470
Old 07-06-2007, 01:03 PM
Holes
It is fine for the templates to have a few holes in them if that helps with the hold-down setup, though I would hope none of the holes are closer than an inch to any edge.
The Perfect Circle - Need Help ScoobyDoo FeatureCAM CAD/CAM 11 01-17-2007 04:41 PM
circle in G-gode fred klusmann G-Code Programing 7 01-15-2007 07:21 AM
Circle problem Captain Midnigh Milltronics 3 11-09-2006 02:11 PM
milling a circle osomaker Fadal 7 08-13-2006 08:04 PM
Text around a circle tsalaf Rhino 3D 2 09-24-2003 10:33 AM
