Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 06-21-2007, 10:58 PM
AustinT is on a distinguished road
Need a cylinder for a music box
I am building a present for a friend and need a part built if it is feasible. I would like to build a music box and need a cylinder built. I am going to take an existing music box and use all of the parts except for the cylinder with the pegs. The pegs pluck the notes at the correct times to play the song. Just looking at some music boxes the cylinder is about .5-.75 inches in diameter and about and inch long. To build the cylinder first a piece of stock would need to be turned to the correct diameter. I think aluminum would be fine. Then on a mill with a rotary axis the cylinder would be incremented and drilled. I would later push some pins into the drilled holes. I can figure out where all the holes need to be drilled to play the song I just dont have the mill to make it myself
Any Idea how difficult it would be to build this part?
Thanks Again
Dan
Old 06-21-2007, 11:30 PM
wildcat is on a distinguished road
Super cool idea! Should not be terribly difficult for someone with a CNC mill and CNC rotary table. Would be interesting to know how they used to be built though. Oh, just noticed the dimensions you have listed... going to be some pretty small holes and pegs...
Old 06-21-2007, 11:55 PM
I Just looked at a cylinder in a music box and it is small . I think the pegs would have to be a stiff music wire.
Old 06-22-2007, 04:46 AM
Gold Member
InspirationTool is on a distinguished road
Seems like a reasonable thing to do on a 4 axis mill.... You may want to provide a list of hole locations with X axis and A axis specified rather than a model. It would be pretty easy to write a G code program that way.
Make sure you do one yourself with a drill press to test your hole/pin methodology first.
You will need to decide if you will use spring pins, or dowel pins with a press fit. You might need to build and arbor press jig. You might want to look at brazing or epoxy applied with a syringe.
-Jeff
www.JeffAlbro.net/cnc/
Old 06-22-2007, 08:09 AM
RdHawg is on a distinguished road
I've also seen these done by dimpling a thin sheet of bronze like metal and then wrapping it around a drum with end caps to keep it in place.
Old 06-24-2007, 10:09 AM
Thanks everyone for the feedback
Does any body have a forth axis that would be interested in this project? I thought about making the cylinder out of copper so I can soldier in the pegs.
Old 06-24-2007, 07:59 PM
Hermle UWF851 is on a distinguished road
I will do it if you tell me where to drill the holes (I don't have time to research that). It would be a fun project. You need those every once and a while. I've drilled and reamed .0310 +/- .0001 holes for pins in the past. Will that do? However, .062 pins are easier to press in. I also have the pins.
fknoll@mfg-consultants.com
Making music with plasma cut more CNC Plasma and Waterjet Machines 2 01-26-2007 12:03 PM
Music in the shop dighsx CNCzone Club House 12 06-25-2006 10:53 PM
Scanner Music CNC Sanghera CNCzone Club House 4 01-22-2006 08:58 PM
compressor piston cylinder compared to an IC engine piston cylinder CNCnUtZ I.C. Engines 1 12-28-2003 07:06 PM
