Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 06-17-2007, 08:24 PM
Zamm is on a distinguished road
Plastic sheet work
Hello, I am looking for someone to cut .090" thich vinyl sheets into guitar pickguards. I have around 15 -20 different designs and will need at around 20 of each for my first order. If all goes well after the initial order I will plan on ordering another 500-1000 toatl per order.
I can send tracings for the initial quotes, after that I can send the actual samples to copy.
zamminc AT gmail DOT com
Old 06-18-2007, 06:43 AM
Verfur is on a distinguished road
Zamm,
Is this hard vinyl sheet or plyable like seet covers type? Both could be cut on a water jet pending if it getting wet matters.
Old 06-18-2007, 07:05 AM
laserboy is on a distinguished road
email at laserboy68@aol.com and I will quote it for you. using laser cut
need to know exact material type, thickness, tolerances, edge finish requirements,
we are in IL. just north of Chicago.
Dave
Old 06-18-2007, 02:36 PM
Originally Posted by Verfur View Post
Zamm,
It is a hard vinyl sheet. Water jet is ok, some pieces will need a beveled edge and countersunk screw holes.
Old 06-18-2007, 02:45 PM
Dave
E-mail sent!
Old 06-26-2007, 08:34 AM
MIKA Tool Rikk is on a distinguished road
You've got mail!
Post Your Glass/Plastic or Stone CNC Work Here JavaDog General CAM Discussion 16 01-04-2010 01:20 PM
3D 'Probe' machine, in plastic, for RF work? gacrwell Mechanical Calculations/Engineering Design 1 06-13-2007 11:23 AM
RFQ - Cutting Thin Plastic Sheet ukchris Employment Opportunity 13 12-06-2006 08:16 PM
RFQ for Sheet Metal Work Rob_M. Employment Opportunity 6 02-13-2006 01:14 PM
Images Milled on Plastic/Acrylic Sheet High Seas Glass, Plastic and Stone 6 06-10-2005 11:44 AM
