Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 05-24-2007, 11:12 AM
gravydrive is on a distinguished road
Request Closed: Small Aluminum CNC Job
**Drawings attached to post #7**
I've got a small job that I'd like some quotes for. It's quite simple, and after the initial prototype, I may consider ordering a batch (30-50 more).
Mike
Old 05-24-2007, 04:25 PM
levelzero is on a distinguished road
What sort of tolerances? Do you just want one to start? What sort of surface finish? What material?
Old 05-24-2007, 05:19 PM
Yes, just one to start. So a quote for just the one piece, and if possible, a quote for another 40. As far as the material goes 6061 should do, but 7075 is preferred. Quotes for both would be nice, but I don't want to make this too complicated. I don't have a preference on the finish, you can just pull it off the machine and chuck it in a box with my name on it. The tolerance on the edges doesn't matter much, maybe +-1/64", but the two drilled holes on top (the thinner piece) need to be fairly accurate to insure proper mating with another part.
Thanks,
Mike
Old 05-24-2007, 05:25 PM
Are you able to provide drawings or a sample?
Old 05-24-2007, 05:39 PM
Yes, dwg drawings will hopefully be up, tomorrow.
Old 05-25-2007, 08:47 AM
besc is on a distinguished road
Hm. Looks intersting. How about a dxf file also. Mike. conmach.com
Old 05-30-2007, 10:47 AM
Alright, I have some drawings. They are drawn in scale, their intended use is only for a quote: very slight changes may be made down the road, and some of the measurements depend on the thickness of the aluminum being used (which will be decided once a specific company is given the job.
I also have a related project that I'd like to see if I get someone for. I need some laser cutting done on fiberglass (G10 material, I will ship this to whoever takes the job). This drawing is more or less what needs to be done, but there will be 4 holes (2 of these countersunk) that need to be drilled (I don't have the exact distances, I'll update the drawing once I get them, should anyone express interest).
These drawing are just aerial views. The aluminum plates should be ~2mm, and the fiberglass is 1/16".
After looking at the drawings, and comparing them to the above picture, you'll notice the spacer between the two plates is missing. This is because I don't know the standard sizes for aluminum square rods. Currently, I have the dimensions correct for an 8mm rod. I can change this to suit whatever materials are readily available. The spacer will be ~1cm long, with tapped (to suit M3 screws), drilled holes on either end.
Email me at gravydrive@aol.com if you have any questions, or if I need to revise anything.
Thanks,
Mike
RFQ - Aluminum Parts - small job F500 Employment Opportunity 8 06-08-2007 03:30 PM
RFQ - Small Aluminum Control Panel grmnfox Employment Opportunity 7 01-21-2007 07:54 PM
Small Lot of Aluminum Castings Needed stang5197 Employment Opportunity 6 01-02-2006 07:21 PM
contouring aluminum with small bit corpse Benchtop Machines 6 09-14-2004 01:11 PM
Bending small aluminum rod Twmaster Bending, Forging,Extrusion... 9 08-06-2004 07:50 PM
