Results 1 to 3 of 3
Thread: aluminum project
    Oct 2004
    aluminum project
    it is .075 6061 aluminum sheet will need 5 holes drilled and 5 that say powered by mitsubishi and 5 that say powered by 4g63T I will send the mating part so that fitment will not be a problem.also qoute with polishing and without.dimensions a 15" x 5" tolerance is as long as it fits mating part with no alignment issues. If this goes well have alot of other projects.
    AMW
    AMW is offline
    Registered AMW's Avatar
    Mar 2007
    Do you have a .dxf / solidworks file to share? (( we use mastercam8 and bobCAD.CAM 21.5.2 ))
    What are the hole locations and Øs?
    How many do you need?
    look forward to hearing from you
    thanks
    e-mail us the above info off our profile and your contact info please!
    AMW
    Oct 2004
    no dxf needed I will send mating part it is not a difficult part.just don't have a machine to do it. go on ebay and look up a dsm spark plug cover for a visual.I will need 10 to start.
  1. Steele and aluminum first project
    By Coogrrr in forum Open Source CNC Machine Designs
    Last Post: 08-04-2011, 05:49 PM
  2. DIY Project with MDF
    By studysession in forum DIY CNC Router Table Machines
    Last Post: 01-08-2007, 02:57 PM
  3. Need help on DIY Project
    Last Post: 09-03-2006, 05:26 PM
  4. First project
    By Xterrian in forum Coding
    Last Post: 10-01-2005, 02:24 AM
  5. My CNC Project
    By mojy2k in forum DIY CNC Router Table Machines
    Last Post: 04-28-2005, 03:17 PM
