Results 1 to 2 of 2
Thread: CNC Program Needed using Fanuc/G34
    May 2007
    Can you or someone you know of write a program for Fancu CNC lathe controls, to cut a variable lead tapered thread? We believe it requires use of Code G34 but there may be other ways. Lead change per rev will increase in the 5th & 6th decimal places. (like 0.0000XX”) A successful program, proven by machined parts, may lead to continuing part-time work. Your referrals will be much appreciated.
    Apr 2007
    do you have a cad drawing of the part? i do mostly milling code but i could see what i can do for a lathe, i have the capibilities. i would like to try and see if i can help!
  1. Newbe - Program Help needed
    By deleteallusers in forum Mechanical Calculations/Engineering Design
    Last Post: 04-10-2007, 02:36 PM
  2. First Program - Help Needed
    By TZ250 in forum Milltronics
    Last Post: 03-26-2007, 01:38 AM
  3. Program needed for waterjet
    By Traceman in forum General Waterjet
    Last Post: 04-25-2006, 01:53 PM
  4. CNC Lathe info/Program needed
    By sofl_g in forum General Metalwork Discussion
    Last Post: 04-12-2006, 11:00 PM
  5. EZ Track DX Program Needed
    By Monk in forum Bridgeport and Hardinge Mills
    Last Post: 08-08-2005, 08:25 PM
