| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
Our client is a major oilfield service company located in North Houston. We are seeking CNC/NC machinists with at least one year of experience. This is a direct hire opportunity. A brief job description is below. Mazak/Mazatrol experience is a plus. Interested, qualified candidates may email their resume to carolyn@rowland-group.com Candidates must be located in the greater Houston area and/or be willing to pay for their own relocation to Houston. Sets-up and operates special purpose equipment, conventional (lathe and/or mill), and/or numerical control (NC) machines and machining centers for fabrication of metallic and nonmetallic parts. Ability to apply basic concepts of algebra and geometry. Ability to calculate and set controls to regulate machining factors such as speed, feed, coolant flow, depth and angle of cut, or enter commands to retrieve, input, or edit computerized machine control media Troubleshoot equipment and perform corrective maintenance in breakdown situations. Knowledge of Mazak and/or Mazatrol is a plus. Candidates must be open to any shift. Shift differential paid for 2nd and 3rd shift. Last edited by trg77056; 04-12-2007 at 02:48 PM. |
| Glad I found this site. At least people here are knowledgeable, care, and are williing to share that knowledge. I have already learned a couple things. BTW, the last guy we employed came from Burger King. At least he knows how to fry the tools! |
The other trend I'm seeing is the growing number of companies using agencies. Once I encountered a man from an agency with supposedly 20 years as a toolmaker who could not figure out why he could not drill a hole on a Bridgeport. He was running the spindle in reverse. He lasted about 20 minutes. lol. I'm one of those dinosaurs you speak of g-codeguy, lol. I have to agree with you. "Made in America" has lost much of it's meaning. Talk about lack of common sense... I started a new job about a month ago. One of first setups there was a job previously programmed by my boss, who's run the shop for 12 years. I was told to use a 55 degree boring bar to finish (3 degree lead angle). So I run off 12 pieces and the boring insert breaks at the back of the bore. On steel tube material. So I go to my boss and tell him I can't make a 45 degree ID chamfer with that 55 degree tool. He was like, why not?- he does it all the time with that bar. When I explained there's only 32 degrees maximum clearance, his answer was that it's just a corner break and don't worry about it. No 35 degree bar in house. I had 4 more inserts and 600 pcs to run, lol, so I edited the program and broke the edge with a red handle during cycle on my own initiative. I don't understand how that job was run before. Now my boss pretty much doesn't tell me how to do jobs on the Okuma, he just feeds me the jobs. I like it like that. I left Chicago 5 years ago and I've encountered more lack of common sense in the past 5 years on the Wisconsin border than I did in 24 years in Chicago and nearby areas. I think a large part of this is the trend noted by mad mark. btw, I'm still feeling out this forum, and it's nice to see comments like yours. |
| Roadrunner, I've been on here less than 2 weeks. I spent some time reading posts that I hoped would fit in with what I do. Some of the names I remember are Geof, Gar, Steve, cadcam, Al, Mark, and a couple others. They all are much more knowledgeable than I, and are willing to help others. I've been programming lathes for the last 22 years. Worked in sheet metal before that...programming the last 1-1/2 years before the company closed down. It was in business for more than 100 years. Hope I wasn't the cause of its closing! ![]() My biggest problem has been working for the same company all these years. You have a chance to learn more by moving around. Not fond of that personally. The moving, not the learning! I wrote some master programs for families of studs ranging from 10-32 to 1/2-20 (from 8620) years ago after finding out about macros. Only dimension that changed on these studs was the dimension from the face to the 1st shoulder. Learned how to use IF statements about a year ago. Just finished a master program Friday for a new family of 3/8-24 studs made from X30 material. All the Z-dimensions vary. Set-up person puts the print dimensions in variables. This program uses 500 series macros for controlling diameter offset wear only, and common variables for everything else. Was using 500 series macros for everything before that. I am kind of proud of this program. Material a different size this time? Want to change the DOC, SFM, maximum RPM, or Feedrate for roughing? Running a long part and the finish turning tool is chattering? Get crossed drilled in the threads? Cross drilled next to the head? Does it get any internal work? (Bore & drill sizes standard.) Length of the bored hole change? Depth of the 7/64 inch drill change? Want to change the cross drill RPM? Its feedrate? All handled by variables at the beginning of the program. Program sets the workshift. Can't change the workshift based on the part length once it goes below 1.3 inches or the thread roll tool won't clear the wall. Program checks for this and sets workshift accordingly. Parts getting cross drilled next to head require an extra .4 added to the workshift for the live tool to clear the spindle nose. Program takes care of this. Adding a couple more variables for controlling the different diameters that the 8620 studs have should allow me to run 3/8-24 studs from any material, of any material size, and with varying diameters with just this one program. Naturally this can be done for all the others size studs. I am looking forward to taking this on-line course. Should be a big help. http://www.universalclass.com/i/crn/8888.htm And a big "Welcome" to the forum. Lots of good information here. If you have a problem, just ask. Someone is usually willing to help. I apologize for the long post, but none of my friends are interested in this stuff. At least on here the people are machinists, and although they probably don't a hoot about my ramblings, it does give me a place to chat with someone that can understand what I am talking about if they do decide to take a read. |
| g-codeguy, No need to apologize for the length of your post, I enjoyed it. None of my friends are interested in this stuff either, lol. I agree, working in job shops yields more knowledge as opposed to working for a company which only manufactures it's own products, and I always like to learn more. The moving around is getting old though. That course you linked to looks good, I'm interested myself now. Thanks for sharing that link. I think you should be proud of your stud macros, especially if you've taught yourself how to use parametric programming. The extent of my parametric programming experience has been for probing. Imho, parametric programming is fascinating. I think you've made great use of it so far. Thanks for the welcome, and I'm looking forward to bumping into you here on the boards. We probably look like a couple of thread jackers to trg77056 right now tho, lol. So far I'm impressed with this forum. |
| I suspect in the case of this Houston employer, it's not that they wouldn't like someone with more experience, they are just willing to settle for as little as a year because they are bombed with work. At $3.30 a gallon, a lot of drilling projects make sense that aren't worth doing at lower fuel prices. trg77056, please correct me if I'm wrong. Dave |
| The guys I was getting in my classes were very disapointing. It seemed impossible to motivate most of them no matter what I did. I had one guy ask me if he was getting at least a C for a class. I asked him "dont you want to do better than that?" His reply was "as long as I get a C, my boss will pay for the class." I told him "you better either get busy in class or start saving some money" I did have the pleasure to work with a few students who was not only highly motivated but was very disapointed if their work was not exceptional. They made it all worthwhile. I was disapointed that few of the students ( maybe 1 in 15 )were actually getting certified in Tool & Die. Most recieved machinist certification due to the fact that the shops they worked in did cnc production machining. They were all required to take the same classes. |
#10
| Hey you guys, your looking in the wrong place! There are some absolutely killer jobs in Sacramento right now. All most all of them are $25.00 to $40.00 an hour!!!! I've been seeing this phenomenon for about the last 6 months. If you got any real experience I suggest here is a good place to start. |
#11
#12
The pay range sounds good. How was the pay range before? (prior to the previous 6 months) I haven't considered relocating to California- but maybe it's time for me to give it some thought. |
| Women CNC Machinists? | TXdragonfly | CNCzone Club House | 72 | 05-20-2012 10:25 AM |
| CNC Machinists Wanted | tparks | Employment Opportunity | 2 | 12-27-2006 01:44 PM |
| Need CNC Machinists in MASS | StarCatcher | Employment Opportunity | 20 | 10-27-2006 01:14 AM |
| Master Machinists | djbowser | Employment Opportunity | 0 | 08-30-2006 11:10 AM |
| Poll for all machinists | HuFlungDung | OneCNC | 20 | 06-30-2003 11:59 PM |
