Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 03-30-2007, 06:02 PM
apexmotion is on a distinguished road
RFQ Delrin and Stainless parts for a pumphead
Hi
We want to build a prototype for a peristaltic pump that would be used for pumping bakery icing. The persitaltic pump is a pretty simple design, flexible tubes containing icing are squeezed between the platten and the rotating rollers.
This is just a prototype, so if you see anything that would simplify or use "off the shelf" parts I'd be open to it. Assume that the fractional dimension tolerances are +- 1/32". Otherwise machined tolerances are given.
Thank you
Doug Antonides
Old 04-01-2007, 12:01 PM
dvsmac is on a distinguished road
Am I correct in assuming the stainless will be 304 or 316 as its for the food industry, and the Delrin will be white?
Stuart.
DVS Machining & Fab
Old 04-03-2007, 08:40 AM
sawbuck is on a distinguished road
i have sent you a quote in your private messages.
Old 04-03-2007, 09:58 AM
Quote for Pump Head
I have sent you a quote in PM
Old 04-10-2007, 12:10 PM
ltmquik's Avatar
ltmquik is on a distinguished road
Is this bid still open?
Jeff Lange
Lightning Tool & Manufacturing, Inc.
Old 04-10-2007, 12:36 PM
Peristoltic Pump Quotes - Thank you
Thanks to all of you for your responses. We received a large number of quotes (around 7 I think) and most were well specified. It turns out that one of the responses was from a well equipped shop just down the street. This is a big advantage for the trial and error nature of prototyping. FYI, the quotes ranged from about $1500 to $3500 - material supplied including fasteners and assembly. Delivery Times ranged from 2 weeks to 5 weeks. The design was slightly simplified to have smaller side plates and the rollers will be grooved instead of the plattens. Thanks again to all of you.
Old 04-11-2007, 06:02 AM
Square Tech is on a distinguished road
Thanks for the feedback.
Old 04-11-2007, 07:35 AM
AMW's Avatar
AMW AMW is offline
AMW is on a distinguished road
Notification of "Post Closed"
Yes, I second Square Tech's comment . There are a lot of RFQ's being left hanging, it is good to see that some Buyers take the time out to notify us Suppliers. Thank you for the opportunity to quote your RFQ.
AMW
small stainless parts fastolds Employment Opportunity 3 03-09-2007 09:02 AM
teflon and delrin parts RFQ fastolds Employment Opportunity 2 02-15-2007 06:48 AM
RFQ- Small diamter delrin parts sleepy23 Employment Opportunity 2 09-07-2006 11:22 AM
Need delrin parts to build jgro machine cwdance1 DIY-CNC Router Table Machines 6 01-03-2006 02:53 PM
RFQ: Stainless Steel Parts MadFlava Employment Opportunity 5 07-30-2005 01:43 AM
