Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 01-28-2007, 10:39 PM
98vert is on a distinguished road
RFQ for 3 parts - 8620 steel
Hi Everyone,
I'm looking to find a supplier for 3 different components. I've attached some pics. I have prints for the people that are interested in discussing further.
Parts are all made out of 8620 steel and relatively small. The trunnion is roughly 1.375" in length and .75" dia. The ring is .25" wide and about .550" in dia. The socket is about .5" in dia jand ust over .25" in length. The parts all need to be carburized, and may need a grind operation on some features depending on the finish and tolerances you could hold.
Annual volume is between 8-10K each. I would be ordering in lots of 500-1000 at a time (up for discussion). I'll be needing 35 prototypes of each prior to first order.
Preferred timing for parts - 35 prototypes of each component (4-6 weeks), production volume after prototypes are validated, (12-14 weeks)
Let me know if you'ld like to get the prints and discuss in more detail. A confidentiallity aggreement will need to be signed. Look forward to hearing from some of you. Thanks.
Rob
Product Innovations LLC
860-517-9648
ID:	30538   Click image for larger version
ID:	30539   Click image for larger version
ID:	30540   Click image for larger version
Old 01-29-2007, 07:52 AM
Moderator
coalstove is on a distinguished road
Hi Rob,
Send me drawings and spec, be more than happy to quote
Chip
Chip Coale
Old 01-29-2007, 09:21 AM
HIRAH is on a distinguished road
pm sent
Old 01-29-2007, 01:16 PM
Quckslvr is on a distinguished road
Rob,
Send me the files in DXF or DWG and I will be happy to get you a quote.
Anthony Holmes
Quicksilver Metals LLC.
317-876-9108
Old 01-29-2007, 11:13 PM
Chip Maker
ricotututi is on a distinguished road
Hi Rob
Please send me the prints if you can we are a CNC Swiss company and we can do prototypes and production with no problem e-mail me the prints to
rico22t@msn.com
626 339-9007
www.miponline.com (check our website for company information)
Old 01-30-2007, 06:55 AM
peterbb is on a distinguished road
Hi Rob
I am new to this sight but I would be interested in quoting these parts. Please sent me some prints.
Peter Boyd
Manufacturing Manager
Atlantic Hardchrome Ltd
5 Notting Court Dartmouth, Nova Scotia
Canada ( Sales office in Wilton, Maine)
1-800-565-3606
email : pboyd@atlantichardchrome.com
Old 01-31-2007, 08:14 PM
northernmach is on a distinguished road
Please send drawings
Rob,
I am with a machine shop in New York, and we are trying to find work for our turret lathe. Please send drawings to nmi@northernmachininginc.com
visit our website at:
www.northernmachininginc.com
Thanks,
Chad
Old 02-01-2007, 09:04 AM
NC Cams is on a distinguished road
One of the two parts appears to be a pushrod socket for a roller rocker arm and the other the ball socket for the pushrod for a similar device.
Although carb'd 8620 should be adequate for a "street/hp" rocker pivot shaft, you might want to consider tool steel for true, hard core racing. Not much of a $$$ premium but oh so much better parts!!!!
Why tool steel? We're seeing cases (Craftsman truck/Bush) racing where 8620 had demonstrated marginal durability.
On the other hand, not only are the tool steel parts more robust, they are much nicer to machine and we have less problems with size change/warpage in heat treat.
The pushrod socket is very lubrication sensitive - they are also very load and finish sensitive. You might want to consider either H13 or O6 tool for these instead of 8620. Besides better wear characteristics, the O6 machines MUCH nicer and finishes MUCH nicer and EASIER than 8620.
Unless you use aircraft quality/bearing quality certified 8620 for the trunion at least, you can end up with some real lame, inconsistant imported crap to work with (voids, inclusions, seams, you name it).
The voice of experience......
RFQ: 35 parts 4340 steel Eddieweeks Employment Opportunity 1 08-21-2006 12:17 PM
advise for tiny stainless steel parts jason_l Benchtop Machines 9 08-07-2006 06:46 PM
Annealing steel parts after welding? Edster Welding, Brazing, Soldering, Sealing 9 03-31-2006 04:38 PM
RFQ: Stainless Steel Parts MadFlava Employment Opportunity 5 07-30-2005 02:43 AM
RFQ - small mild steel turned and drilled parts mcmmach Employment Opportunity 8 07-28-2005 10:37 PM
