Hi, I'd like to quote, just have a couple questions.... what size chamfer is on the end and how long is the knurl from the face? is it a critical dimention?
It's likely I can run these for slightly less, but don;t know how long it would take just yet.
The knurling length is not critical, however it must uniform for all of the pcs.
Any length between 0.2120" to 0.3600" will be fine (just need to be the same for all of the pcs.). The knurl must be a straight tooth course style knurl. Also knurl needs to be perpendicular to the part (it cannot be "deeper" on the top and "shallower" on the bottom portion of the knurl).
The chamfer is simply to break the sharp edge. The part is drawn with a 45° at 0.100".
