Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 11-27-2006, 01:29 PM
markjb is on a distinguished road
open machine time
BODEKER MACHINING INC
21810 ST HWY 55
GLENWOOD MN 56334
Phone 320-634-4216
Fax 320-634-4216
email: mbanks63@hotmail.com
Are capabilities are as follows.
cnc lathe daewoo 300 L 4" thrue hole / 51" between centers 12" chuck
cnc lathe daewoo 240 L 3" thrue hole / bar feeder 10" chuck
2 cnc lathes hitachie seikie's 2" holes
cnc fadal 4020 vertical mill
engine lathe 10" swing over cross slide taper attachment 71" c/c 15" chuck 20" swing over ways
hem saw 12 x 12
misc drill presses, sanding, and welding
If you have any machining that you need that would fit this equipment I would like an opportunity to give you a quote.
Mark Banks
Bodeker Machining INC.
Old 10-16-2007, 04:40 PM
we have entered our slow time again www.bodmac.com
Old 10-21-2007, 05:01 PM
BAD DOG is on a distinguished road
Where In Glenwood Are You Located,,
I Used To Rent Lonnie Armstrong's Building At The Top Of The Hill (years Ago)
Bad Dog
Old 10-22-2007, 01:58 PM
we're on 55 down by john deere and the old case IH buildings
Old 11-13-2007, 11:51 AM
squale is on a distinguished road
hey Mark do you work off of solidworks .slprt part models? or do you need 2d drawings?
