Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 11-22-2006, 11:19 PM
Nova9911 is on a distinguished road
RFQ Capabilities Master List
Thanks to everyone who responded to my previous post for the filter. I am glad to have ordered from one of the quotes I received here.
I am building my vender list and have logged everyone who quoted. I would like to add a database field for capabilites/preferred type work. I am sure others could use this list as well.
Please list the type of work you prefer:
- sheet metal (bend/stamp/roll, max length)
- welding/fabrication (arc/mig/tig)
- painting/powder coating/anodizing
- turning (diameter and length capacity)
- milling (maximum external dimensions)
- laser or waterjet (max thickness)
- cnc or manual machining
- prototype or high volume
- General Geographic Area
I hope a list such as this could help others as well.
Thank you,
Ron
Old 11-23-2006, 08:59 AM
Runner4404spd is on a distinguished road
Superior Design Concepts
Turning Work 9" round - 12" long
Milling Work 30x12x15
General Location Detroit Michigan, although not in detroit. also have design and cad capability. primary software Solidworks.
586-350-8561
jerry@superiordesignconcepts.com
http://www.superiordesignconcepts.com
Old 11-23-2006, 09:35 AM
rkdygert is on a distinguished road
P&D Mechanical Machines/Capabilities
P&D Mechanical specializes in prototype/small run production but can accomodate higher production runs. In addition to the machines listed below, we also offer drafting and design support using Autodesk products. We are located in Upstate New York.
CNC Milling
-B'Port 3-axis CNC mill, machine envelope approx 5"x15"x30"
-B'Port 3-axis CNC mill, machine envelope approx 5"x15"x18"
-Anilam Crusader 3-axis CNC mill, machine envelope approx 5"x15"x30"
CNC Turning
-Hardinge CHNC High Precision CNC lathe, 14" swing, 12" length; accuracy to 0.00005"
Manual Milling
-2 manual knee mills; B'port & Cincinnati
Manual Turning
-4 manual lathes ranging in size from 10"x24" to 24"x96"
Grinding
-Brown & Sharpe cylindrical grinder
-2 surface ginders
Welding/Fabricating
-Arc, Mig, and Tig welding
-Plasma cutter
-4ft shear
-8ft brake
Thank you,
Ryan K. Dygert
P&D Mechanical
Old 11-23-2006, 10:55 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Integrated Mechanical Services Inc
CNC Milling
-4 axis VMC 40x20x28
CNC Turning
-2 axis chucker 16x40
Boring Mill
- TOS WHN 9B 50x36x40 (point to point CNC)
Manual Milling
-3 knee mills
Manual Turning
-3 lathes max size 36x160 (44 in gap)
Grinding
-TOS cylindrical grinder 12x30
-2 surface ginders 12x36 max cap
EDM
- Excello tapping machine
- Fine Sodick AC3R 4 axis plunge
Fabricating
- Haco CNC shear, 10 ft. by ½" steel capacity
- Haco CNC brake, 12 ft. by 165 ton.
- Kingsland 45 ton Ironworker
Welding
- C.W.B. Certified SMAW, GMAW, FCAW and TIG welding; All Position
- TSSA Certified pressure vessel welding
- Plasma cutter
Misc
- HydMech saw
- drill presses, band saws, belt sanders, portable equipment.
- Freightliner truck and forklift fleet for rigging/ moving
- Warehousing
Thank you,
Derek
Southern Ontario Canada
www.integratedmechanical.ca
Old 11-27-2006, 02:15 PM
admach is on a distinguished road
A&D Machine, Inc
Redgranite,WI
CNC Milling
20x16x20
54x26x25 with 4th axis
CNC Turning
13x36 / 2.5 thru spindle
10x12 /2.562 Thru Spindle / 4' bar loader
Old 11-27-2006, 08:47 PM
Gandalf is on a distinguished road
Cool see our site
www.northsimcoetool.ca
Old 11-28-2006, 12:41 AM
big_mak is on a distinguished road
CNC Milling up to 4 axis
40X20X25 10K 30hp
In Vancouver BC
"It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
Old 11-28-2006, 06:51 PM
pp-TG is on a distinguished road
PRECISION PLUS
GLADSTONE, MI
CNC MILLING:
20X16X18
CNC TURNING
OKUMA LB9C (TWIN SPINDLE)
MAX TURNING DIA. 5.5"
MAX TURNING LENGTH 10.5"
EMAIL- precisionplus1@sbcglobal.net
Old 11-28-2006, 07:04 PM
mikeh78's Avatar
mikeh78 is on a distinguished road
Hesse Machine
Eden Valley MN
CNC Milling:
15x12x10
Manual Lathe:
4x12
Cadcam
10 years experience
Garage shop, Low Hourly rate.
www.hessemachine.com
michael.hesse@hessemachine.com
Old 11-29-2006, 12:53 PM
slucas_clmach is on a distinguished road
CL Machine, LLC
430 S High, Unit C
Joplin, MO 64801
ph/fax: 417 659 8765
cell: 417 438 9437
email: clmach@sbcglobal.net
CNC Milling: 40 x 20
Turning: 18 dia x 60
EDM-
Wire: 8 x 12
RAM: 16 x 12 1320 lb
Surface Grinding: 16 x 36
Manual Milling: 9 x 30
We are a small family owned business. Our father and son duo has over 60 years of combined experience. We've been in business for a little over two years and are eager to build our contact list.
Shawn Lucas
slucas@fastfreedom.net
  #11   Ban this user!
Old 11-29-2006, 02:45 PM
JPMach's Avatar
JPMach is on a distinguished road
Check out Website
www.jp-machining.com
CNC milling 50" by 20" by 25" work envelope
CNC barfeed turning 1.25" max bar
JP
  #12   Ban this user!
Old 12-01-2006, 01:52 PM
SeaSchell is on a distinguished road
CNC 3 Axis Milling: 40"x 20" x 20" with 4th Axis up to 6" Ø
CNC Turning: 2 1/8" Through the spindle. 40" between centers. 16" over ways.
MIG/TIG Welding
CAD/CAM: Programming & Mechanical Design
All other process' available through local contacts ie: heat treat, coatings, EDM , grinding etc.
After 35 years in Machining, Manufacturing, Engineering, Management I have decided to get back to my roots and opened up my shop a year ago. I specialize in prototype, short run production from hard to machine materials etc.
Our Motto:
"The improbable we do right away.....The impossible just takes a little longer!"
Dave Schell, SeaSchell Tackle Machining/Mfg./Design daschell2@cox.net 619 562-1835
