Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 10-29-2006, 12:06 PM
Enraged is on a distinguished road
RFQ - Small CNCed aluminum part, batch of 50
I'm looking for a RFQ for a small part that I would like CNCed. I have attached a zip file with the Solidworks part. If you would like a different format, let me know.
I am looking to get a batch of 50 done, with more possibly in the future. Material is aluminum.
They would be shipped to Victoria BC Canada, postal code is V8M 1M3 if you would like to include a rough shipping estimate. A local shop quoted me CDN$1200 for all 50 (which works out to $24 each), so I am looking for something lower than that.
If you would like more info, please post questions. Thanks!
FS: Complete Z-Axis Assembly with THK RSR15WM slide, leadscrew, stepper mount. PM for more info.
Old 10-29-2006, 12:41 PM
Attached is a PDF drawing of the part for those that can't open Solidworks part files.
Old 10-29-2006, 01:55 PM
I revised the drawing to add radius to the small intersections. As per the drawing, this radius can be defined by the tooling you wish to use, as its dimension is not important.
Old 10-30-2006, 12:20 AM
Some people have asked for more info on tolerances and surface finish, so here goes:
Tolerances of +/- 0.005 should be more than enough, and surface finish is not important on the outside profile, only on the inside bore, so the outside could be simply roughed, and the 4 holes simply drilled, no reaming/boring required. As for the main bore, a good finishing pass would be adequate. This is just for a car shifter mechanism, and they are based around factory dimensions.
Feel free to PM me if you have more questions. Thanks everyone!
Old 10-30-2006, 08:07 PM
zcases's Avatar
zcases is on a distinguished road
Can you provide a step or iges format of the solid model?
Please send to zcases<at>frontiernet<dot>net if possible.
Scott
Old 10-31-2006, 08:35 AM
JPMach's Avatar
JPMach is on a distinguished road
Enraged, Your PM box is full. I couldn't respond to your question. Please email me at the address I gave you in my first pm.
JP
Old 10-31-2006, 11:11 AM
PM box cleared, and I will post an IGS file when I get home from work.
my email is t.harcombe at shaw dot ca
Old 11-02-2006, 12:23 AM
heres the igs file
Old 11-02-2006, 12:32 AM
daleman is on a distinguished road
would you be opposed to a uk firm making these as i have a haas super mini mill with no work for for a week or two.
Old 11-02-2006, 09:13 AM
j-radkemachine is on a distinguished road
you have a p.m.
  #11   Ban this user!
Old 11-02-2006, 09:34 AM
Are you aware of the shipping cost from the UK to Victoria, B.C. Canada and the brokerage charge for Customs clearance?
  #12   Ban this user!
Old 11-02-2006, 10:56 AM
geof,
you might try sending that e-mail again... except this time try sending it to daleman ... i didn't quite understand the reply i got & think you may have meant to direct it somewhere else.
