Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 10-05-2006, 12:55 PM
LMRecruiter is on a distinguished road
Lockheed Martin Employment Opportunities
Lockheed Martin in Orlando, FL is seeking Optical Operators/Diamond Turn Operators. Please see below for the the brief descriptions.
Req# 773593 and 773597:
REQUIRED SKILLS: Diamond turns optical elements, Diamond turns mounting surface, Polish micro-optical / maxi , Rough and finish
grind , vacuum coating equipment , coating processes, cut/shape blanks, Production B Physical exam
DESIRED SKILLS: prior optical fab exp
SPECIFIC JOB DESCRIPTION: Specific Job Description:
Polish various types of micro-optical to maxi optical elements to specified optical specified optical specifications. Rough and finish grind
all types of optical elements. Sets up and operates vacuum coating equipment to perform a wide variety of coating processes, sets up and
operates a wide variety of machines to cut and shape blanks for optical elements. Diamond turns all types of optical elements and optical
mounting surfaces to specified requirements. Need to understand written and verbal instructions and work to a variety of work instructions.
Need to be able to pass the Production B Physical exam. Minimum high school education or equivalent desirable. Should possess the
ability to be granted a secret clearance.
Req# 773594
Need to be able to pass the Production B Physical exam. Minimum high school education or equivalent desirable. Should possess the ability to be granted a secret clearance.
Req # 843677
REQUIRED SKILLS: Polish, grind optical elem, diamond turning , vacuum coating , generateoptical elements
DESIRED SKILLS: AS degree in optics
Support Arrowhead program rate increase. Polish, generate, grind optical elements, operates vacuum coating equipment, diamond turning
Required Skills: polish, generate, optical part, grind opitcal elements, vacuum coating equipment, diamond turning
Desired Skills: exp. in optical fab, military spec fab
Relocation offered
These positions can be viewed at [url]www.lockheedmartin.com
To apply directly to these requisitions please go to the Lockheed Martin website and put the requisition(s) into the shopping cart and then submit. This will "attach" your resume directly to each position.
Candidates must pass background/drug screening and must be eligible for a secret clearance.
Thank you,
Stacie M.
Recruiter
Lockheed Martin
Last edited by LMRecruiter; 10-09-2006 at 03:12 PM. Reason: Ad URL so candidates can apply directly to position
Old 10-06-2006, 12:40 PM
LMRecruiter You will get more response if you include compensation.
DZASTR
Old 10-06-2006, 01:12 PM
Unfortunately due to company policy I'm not able to do that. There are couple of reasons why that policy is in place but the #1 reason is because we have a compensation analyst who determines each candidates salary by their education, skills, experience ect.
Regards,
Stacie M.
Lockheed Martin
Recruiter
