Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 09-05-2006, 10:28 PM
JustinM is on a distinguished road
RFQ: 8mm tubes
After searching all over it seems to be impossible to find stock 8mm aluminum tubing.
I will make a .dxf if neccessary. What Im requesting is 5 tubes 3" long 8mm OD and 5mm ID to be made from 2024 or 7075. The OD will be going into a ball bearing to get an idea for tolerance-.005 at the most. I want a snug but not tight fit. ID tolerance can be +.005
No specific time frame requested but soon is prefered.
Please send quotes to teamsawzall@twcny.rr.com
Thank you,
-Justin Mathews
Old 09-06-2006, 12:53 PM
fuzzman is on a distinguished road
Ygem
