Results 1 to 5 of 5
Thread: RFQ - sheet metal (water jet?) with some bending
    May 2006
    Hi guys;
    we're looking for 6 of this part, a bracket for mounting electronics on the back of a video monitor. It's about 9.2"x6.3" with 6 holes, cut from flat stock, with some finish bending. It's an ideal part for someone with a water-jet or similar machine looking for some extra piece work.
    Part Description: Monitor bracket ( see file m_brckt.dxf )
    Quantity: 6
    Material: Aluminum or steel, .070 to .100 thick, alloy not critical, but the two ears of the bracket will be bent up at 90 degrees (to attach a handle between them) so a material that will survive that bending is necessary. You supply the material.
    Edges: approximately square edges, some tool marks from cutting are OK, so long there are no big gouges. Break or deburr all edges, particularly the long ourtside edges. The holes do not need to be deburred, so long as they don't have sharp protruding edges.
    Finish: A quick scotchbrite pass is ideal, but any bright, clean shop type finish is OK. These parts will eventually be anodized black ( if aluminum ), or painted black (if steel ), and if your shop is set up for that, please include a bid for the anodizing or painting.
    Delivery: would like 3 weeks, 4 weeks max.
    Contact: Steve Switaj, Stealth Aerial Cameras, steve@stealthac.com (407) 406-4447
    Also see our other post, for fiber bollard brackets
    Attached Files Attached Files
    Oct 2005
    the dxf is corupt, can't open it, I have a laser shop with material sitting around to do this, if you want e-mail me the drawing.
    Eric Hnanicek
    Brokenlaser@cebridge.net
    Nov 2005
    canada
    I Am Also Having Troubles With Your Files
    Sep 2006
    Quote to you on Tuesday.....need material $
    Dave Schell, SeaSchell Tackle Machining/Mfg./Design daschell2@cox.net 619 562-1835
    May 2006
    Hi Guys;
    Just wanted to let everybody know that we got our vendor for these.
    Thanks to everyone for their prompt replies.
    I hadn't tried posting an RFQ on CNCzone before, and I was really impressed with the speed that all you guys got back to me with very competitive bids.
    We have a bunch of similar parts coming down the pike in the future (we do a lot of these little runs) and I'll e-mail you our files files when things like this come up.
    - Steve
  • Posting Permissions
