| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
Edit: Request has been fulfilled. Thank you for the replies! --------------------------------------------------------------- Hi all, I've finally started construction on the JGRO open source design found here on cnczone but I don't have access to HDPE/delrin or the proper tools to machine it (other than by hand with a dremel). I saw that in older threads Joe2000che used to offer the HDPE alignment blocks and anti-backlash assemblies for pretty reasonable prices, but it looks like he has moved on to his new design. I'm looking for a quote on the anti-backlash nuts, anti-whip block, and router clamp assembly, then a seperate quote for just the alignment blocks as I'm going to try making those from MDF as originally called out first. On all pieces I can do any tapping required but it would be helpful if all the holes are drilled out. For reference these would be the following parts from the JGRO plans here (pdf). All pieces to be made from delrin/HDPE. Name: (Quantity) JGRO part# ------------------------------------ Anti-backlash nut: (3) cnc_dtl_14 nut tensioner: (3) cnc_dtl_15 anti-whip block (1) cnc_dtl_23 Router Clamp Base (1) cnc_dtl_41 Router Clamp Top (1) cnc_dtl_42 2nd quote: ------------------------------------ Lrg Adjustment Block (4) cnc_dtl_07 Sml Adjustment Block (8) cnc_dtl_13 I'm just now starting to drill and tap the MDF so the lead time is very flexible, likely two to four weeks at the earliest. Thanks! Last edited by Jtheletter; 08-30-2006 at 10:16 AM. Reason: order filled |
