| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
I need a quote for 120 5/8" Round Stock 6061 Auluminum Standoffs(spacers). This part is as described. Part is a piece of 5/8" Diameter 6061 Aluminum Round stock that is 1.875"+-.005" long. It has a .25" hole drilled through the length of the part. Holes and edges should have a small edge break or chamfer. Outside diameter and finish is mill finish. Parts Should be as clean, scratch, gouge and dent free as possible. A separate cost to bring parts to an even, fine scotchbrite finish if you would like to quote that as well, it's up to you. A separate cost to get parts to an even Tripoli Buffed finish if you would like to quote that as well, it's up to you. Please include a lead time and approx shipping cost as well (to 60102 USA) Repeat orders are likely. mpstech@ameritech.net |
| Those may be a stock item at http://www.standoffsystems.com/detect.html
| Thanks I found that site as well but none are the correct fit ant it's really overkill for the part. That stuff is cool though. There are several other sites along the same line as well. Any other bids ? I'll be ending it thurs or fri. Mike |
I will email quote shortly Thank you for the opportunity Michael Unmann P2P Machining
I look forward to hearing from you! |
