Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 08-18-2006, 12:13 AM
Eddieweeks is on a distinguished road
RFQ: 35 parts 4340 steel
Attached is a drawing for a main shaft for
a variable pitch propeller for a model airplane with
a 10 hp engine.
4340 tool steel Normalized ... you provide...
I will supply the bearing for the slip fit over the shaft...
Tolerances in many cases are not as tight as drawing shows....
Solidworks part file is available.... Part count 32-35
Time frame 2-3 weeks...deber only
Thanks..
weeks1@bellsouth.net
Eddie Weeks
Weeks Aero Concepts, LLC
Baton Rouge, LA
225-571-2444
Old 08-21-2006, 11:17 AM
Thanks for everyone that quoted the part.. A machine shop a few hundred miles away
Got the job.. Thanks again
Eddie Weeks
