07-06-2006, 09:15 PM
Simple part needed. 3x2" in size. | | I need 2 copies of the parts below. IE, the part below is just for one axis, so I need 2 made. (These are X&Y axis mounts for a homemade machine). The part on the left is made from .75" material, and the part on the right is made from .25" thick material. Part is to be made from aluminum unless steel is cheaper..I dont care which, as long as its the cheapest.
This can be made on a 2-axis cnc, as long as you can control the z-axis depth with a dro. The only critical stuff is the bearing holes (blue circles) and the hole locations.
These are just one-off, for a future DIY CNC member. Please quote for 2x copies. Send all quotes to my email address. I've attached my rough idea, and may only need to update the drawing dimentions by a few thou or so, or clean it up. Thank you for any replies.
Send all quotes to lowecnc@yahoo.com or provide quote in this thread. Thanks. |
